Samsung TV - no backlight, except when mainboard disconnected
  • zoidberg123
    • May 2021
    • 7
    • Israel
    I am troubleshooting a Samsung ue48h6400aw. When plugged normally, trying to turn it on leads to blinking power light 7 times and no backlight. If I press buttons I see the corresponding power light flashing (that it acknowledged the action).
    If I unplug the mainboard from the power board and plug in the TV, the backlight turns on.
    Does this mean it's 100% the mainboard and I should replace that? Or it could still be the power board?
    Would appreciate any input, thanks!
    -Gil
  • neilc6
    • Nov 2015
    • 1550
    Re: Samsung TV - no backlight, except when mainboard disconnected
    I've seen bad tcon boards that cause no video and no backlight in H model years. If the TV turns on on and off with no backlight and no video and backlights come on when forced, I would suspect the Tcon before the main board.
    • zoidberg123
      • May 2021
      • 7
      • Israel
      Thanks for your reply! Is there some test I could perform to confirm it is the t-con?
      • zoidberg123
        • May 2021
        • 7
        • Israel
        Sorry for double post.. I couldn't figure out how to delete my reply
        • neilc6
          • Nov 2015
          • 1550
          Forcing the backlights on confirms both your backlights and power supply are likely good. If the TV turns on and off, the main board is likely good.
          Second test is to power up the TV with only one side at a time connected between the Tcon board and panel. If one side is good, you have a panel fault on the bad side. If no side is good, tcon is still suspect.
          • zoidberg123
            • May 2021
            • 7
            • Israel
            I did this (with the main board also connected I assumed) and if either side is connected, the backlight comes on (but still no display when turning on TV). When both sides are connected, no backlight comes on at all when plugging in.
            I didn't notice any difference in halves of the screen though with either side connected.
            I should order a Tcon then?
            Thanks for your help, I really appreciate it!
            • zoidberg123
              • May 2021
              • 7
              • Israel
              New tcon arrived today and didn't fix the problem. Does this mean it has to be the mainboard?
              • Henke
                • Oct 2022
                • 41
                • Sweden
                Hi, Did you solve the problem? I think i might have about the same problem now with my tv. The backlight only comes on if i have the mainboard disconnected.
                as soon as i connect it, no matter if i have one, none, or both sides on the Tcon
                connected it turns off immediately.
                  • 12206
                  • U.S.
                  check that the tcon fuse is ok, should show continuity.
                  Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND IT'S ALWAYS IGNORED SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS.
                    • 12206
                    • U.S.
                    try it with tcon unhooked from mainboard, see if theres any change.
                    • Henke
                      • Oct 2022
                      • 41
                      • Sweden
                      It does not make a difference. i have noticed that the Ps_on voltage cycles
                      between 0 and 3.3V (on for several seconds and off for a few) any thoughts about that?
                        • 12206
                        • U.S.
                        I think its a mainboard issue, maybe check the voltage regulators on mainboard.
                          • 12206
                          • U.S.
                          some testing there, some voltage regulators are fixed some are not, if not sure which you are dealing with, you can look up the data sheet of the component: https://www.youtube.com/watch?v=ocqnqmBxiqY
                          • Storyteller12
                            • Jun 2020
                            • 624
                            These Samsung “H” series have a problem with the main board. Usually a diode goes bad and takes the ic next to it out also.
                            Probe diode on main board for shorts
                              • 12206
                              • U.S.
                              ^^+10, hell yeah, do that too.
                              • Henke
                                • Oct 2022
                                • 41
                                • Sweden
                                Thank you for the inputs.
                                I found something strange. A component marked with "AA5"
                                Can't find what that is..I also found a couple of shorted resistors around that component. I marked 2 of them in the picture (there are a few more).
                                How do you now what values those should have?
                                  • 12206
                                  • U.S.
                                  measure resistors in ohm mode, my meter reads most under 10 ohm resistors as short in continuity mode but they are not, if resistors are in parallel then the resistance will be half the marked value, instructable there for determining values: https://www.instructables.com/Readin...esistor-codes/
                                  • Henke
                                    • Oct 2022
                                    • 41
                                    • Sweden
                                    i measured i ohm mode. In this case they are not in parallel (i know that formula), they are going to separate legs on that AA5 IC. They are so tiny that it seems like they don't have any numbers on them.
                                      • 12206
                                      • U.S.
                                      not exactly sure but if all those other tiny resistors dont read short, then you might have found the problem or at least part of it, but how to find their value is a good question if not marked.
                                      • Rajnhl
                                        • Oct 2018
                                        • 94
                                        • India
                                        resister never short. they open dead or their value increses.
                                        AA5 ic looks like eeprom 24cxx type.
                                        • Henke
                                          Samsung TV HG46EB690QB No picture, only backlight when disconnected mainboard
                                          by Henke
                                          I came across a Samsung tv that does not seem to start up. When i plug it in nothing happens except that the red led turns on. But when i disconnect the mainboard, the backlight turns on and immediately turns back off when i connect the mb again.
                                          I have tried to disconnect one, none and both cable(s) from the Tcon to the screen but it makes no differens. The PSU seems to work, but when the mb is connected one of the 5V cycles high and low.
                                          Anyone with inputs?...
                                          10-27-2022, 01:01 PM
                                        • stylishconsultant
                                          un60j620dafxza - Samsung No Display Problem
                                          by stylishconsultant
                                          Hi All,
                                          Need help.
                                          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                          09-04-2024, 03:26 AM
                                          09-07-2024, 05:50 AM
                                        • K212
                                          Samsung QE65Q700TATXXC is not starting
                                          by K212
                                          my Samsung QE65Q700TATXXC has stopped working recently. It worked fine during the morning, and when trying to start it later the same day it just refused to start.
                                          The standby LED is working, but nothing happens when pushing the power button, other then the LED blinking once. No picture, no sound, no chime, no relay click. I tried a cold start, and other recommended fixes from Samsung. Nothing worked. Then i even tried to reflash the firmware, but nothing happened, not even flashing of the standby led etc.
                                          I contacted Samsung support who said it is most...
                                          07-31-2025, 12:45 PM
                                        • badboyzzz
                                          Samsung UE50AU8072 all time rebooting, backlight ok. Maybe mainboard faulty?
                                          by badboyzzz
                                          The motherboard initially receives voltage for VGH, but it constantly reboots. When I remove the flex cable at the bottom, I hear normal sound, but there is no image on the screen and it is black on both sides. This time there is no voltage on VGH.
                                          03-25-2025, 10:48 AM
