LG 55UJ6200 BEFORE & AFTER tape fix/fine tuning success
  • alfatv
    replied
    Re: LG 55UJ6200 BEFORE & AFTER tape fix/fine tuning success
    Originally posted by Noobwithamultimeter
    That's an interesting approach. How many pins should I try? Half of the cable?
    I did it only once on UK series, was about 12 pins and result was pretty good.
  • Noobwithamultimeter
    replied
    Originally posted by alfatv
    Try to cover more pins, so you isolate the the whole group of pins driving bad side.
  • jjanssen7
    replied
    In my experience it's just the luck of the draw... the degree the tape method works depends on where the screen is shorted. with some, faint lines is the best that can be done.
  • alfatv
    replied
    replied
    After a lot of fussing with the tape and trying different pins and combinations I've landed on the most successful result. The least amount of pins I can cover are pins 11, 12 & 13. The picture is solid, color is correct and no flicker occurs. There is however very fine lines in the entire image, top to bottom.
    Just want to share this information in case this becomes a predictable fault in this particular panel. I have watched a few videos on youtube and the best fix for a shorted panel seems to be the tape method. They discovered there parallel lines in the ribbon cables and if you cover them, the picture clears right up. https://www.youtube.com/watch?v=kUWapOBtm0Y
    Only question remains: how is it some owners report a perfect picture with this method yet I am still seeing lines in mine? Is there some perfect amount of pins to cover and how can I determine the correct ones? Could a combination work? Like say first 1 & 2 pins covered, skip a few then cover 4 etc... boom perfect picture. I have yet to arrive at that result but I am determined since this set has the potential to be the best quality image out of all the tvs I have found.
    replied
    Also REALLY hoping I don't have to repair these tiny caps:
    replied
    Saw something interesting. There are little gold contacts along the board inside that controls the video signal. Some of them have conductive tape, some do not. One had the tape peeling from it when I openened it to look. Could this be a grounding issue? I'm really crossing my fingers on this one. I wonder if I put some tape on that and make the contact better it will be fine.... Picture:
    replied
    So I removed one long metal guard along the bottom of the screen and when I looked at the sides there appear to be no gate drivers on the left and right sides of the TV. So I am going to focus on the left side of the panel first since I think that is the side that is affected.
    replied
    Ok back at the frame removal, here is a photo of the whole back and I've indicated what line I've been tape masking with different results.
  • ReeceyBurger123
    replied
    Put the Tv on the table on a cloth screen upwards, go around it take the screws out, remove the frame bit by bit or if it’s a solid frame start lifting at the end opposite to the drivers and pcb. Needle DMM probes are advised as you don’t want to put a load of pressure of the small parts with larger probes. I’ve fixed a SONY 55” 4K set that had 1 shorted ceramic cap in a bank of like 20 in parallel it takes time, having an LCR meter can help track down the lowest point of resistance too.
    replied
    The mlcc's are integrated into the panel. Only problem is I'm nervous about getting the outer frame off as I can't find any youtube guides on this model yet, also once I get there I have no replacement capacitors.
  • ReeceyBurger123
    replied
    You’ve almost narrowed it down to the panel, start doing some resistance checks.
    replied
    My best guess is pins 11-14 are affected because I can see a solid image with them blocked, although there are quite a few lines in the image. Also the color is correct. Blocking other lines causes the left side of the image to go kind of slightly lime green due to the yellow being off instead of yellow.
    Here is where I think the lines lead to on the mainboard. There is no t-con board in this set.
    LCD TV will have T-CON. It can be stand alone T-CON board, integrated T-CON into the LCD panel, or integrated T-CON into the main board.
    Can we see the pictures of the whole back side of the TV showing all the board.
    replied
    So it's possible the failure is mainboard related? Could be a mlcc on the mainboard or on one of the gate driver tabs? I think the tabs are very tricky to solder on.
  • ReeceyBurger123
    replied
    The lines pull though a via to the other side of the pcb a magnifying glass would be a big help, they also feed too another part of the board on the top. I’ve seen even the smallest of MLCCZ caps fail short, easy to test multimeter on ground and measure each side.
    replied
  • ReeceyBurger123
    replied
    Crazy. I have it narrowed down to 4 leads covered now. Working on a smaller and smaller piece of tape. Color is correct but there are lines still. Getting very tricky with these tiny pieces of tape.
    Can you trace where they feed too ?
    replied
    replied
    Bad caps can be replaced if you have experience with SMD repair and have proper tools.
    Example of bad MLCC:
    https://www.badcaps.net/forum/showth...44#post1043044
    replied
    Originally posted by budm
    You can try testing resistance of the MLCC (Multi Layer Ceramic Capacitors) on the tab bonding boards to see if any of them show low resistance reading.
    I'd have to take a apart the frame to get at them. Are they repairable/replaceable?
  • RetroComputingGrotto
    IBM LTO 7 Tape Drive - Dust Sensors??
    by RetroComputingGrotto
    I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
    I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
    09-19-2024, 01:54 AM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • triplefour
    LG 75UN8570AUD panel issue fixed with tape.
    by triplefour
    I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
    add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
    07-17-2023, 10:22 PM
  • mecha1166
    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
    by mecha1166
    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
    11-25-2024, 05:22 PM
  • CapLeaker
    Dell ATX PSU won’t start, but forcing it works fine?
    by CapLeaker
    Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
    Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
    10-28-2024, 06:59 PM
