LG 42LC55 - Fixed power fault caps, now NO input on HDMI & VGA, also freezes & B/L !
  • reessi
    • Jan 2016
    • 334
    This TV had the well known power supply issue, took ages to turn on etc until one day it never turned on, I removed and tested all output caps on the PSU with an ESR meter and replaced the ones I've marked in blue on the photo (they are the new ones).
    After this it turns on fine but no signal is displayed when selecting VGA or HDMI 1 & 2 but the laptop always correctly sees the tv and brings up the name and resolution...
    My new flatmate assured me the hdmi's had previously worked after waiting a long time for the TV to turn on but he hadn't used it for at least 5 years.
    Other issues:
    Sometimes it crashes! When changing inputs or plugging cables in the no signal disappears and screen remains blank with backlight, nothing works after that.
    I factory reset it and while it was searching new channels on reboot the screen went gargled and froze.
    I rebooted and re-tuned and now DTV works fine including sound. Although not tested for ages, maybe it would eventually crash or flicker!
    Backlight:
    If watching long enough I noticed the no signal occasionaly distorts, you have to watching for minutes as it is quick.
    Later I noticed from behind that this was in fact accompanied with the backlight flickering for a millisecond but you couldn't notice easily from the front unless expecting it.
    I've tried heating the mainboard and specifically the genesis chip and the power supply board, it makes no difference.
    I notice the hdmi and vga inputs go into the Main GENESIS chip so I'm airing to wards this being faulty and would explain it crashing....
    But the backlight flicker, can this be caused from the mainboard too? I would expect that from the PSU?
    I can pick up a mainboard online cheap enough but it is always more fun to understand and repair and also the backlight flicker throws me slightly!
    NOTE - the DTV seams to not be affected by any issues after being on for 10 minutes.. but when I pressed input button screen went blank with sound... it didn't show input menu but after ten seconds it changed to HDMI input which I did not select as I only pressed input once and that only move it to next input (analogue tv).
    Moving back to DTV now the screen was distorting and flickering but with sound...
    Many thanks.
  • reessi
    • Jan 2016
    • 334
    Re: LG 42LC55 - Fixed power fault caps, now NO input on HDMI & VGA, also freezes & B/
    I also checked the big electrolytic on the mainboard, I know it could also be the silver SMD ones but there are so many that I have not started checking these yet, I thought I would wait for other peoples advice... and heating them alot did not affect it...
      • 12328
      • U.S.
      Could try a firmware update if you can find one.
        • 12328
        • U.S.
        Could try cleaning and re-seating the ribbon cables from tcon to driver board and lvds cable from mainboard to tcon with isoprophyl alcohol.
          • 12328
          • U.S.
          Did you try another device with hdmi besides a pc, like a dvd player etc? Sometimes the pc video card display settings conflict with the tvs, it's easier to troubleshoot with a different device.
          • reessi
            • Jan 2016
            • 334
            Hi mate, I already did a factory reset which I mentioned and that it is where it crashed during the wizard.
            I have already reseated all cables and I've just cleaned the LVDS to be sure and no difference.
            I only have laptops available but I tried several and the result is the same.
            I will look for a firmware update to try..
            Many thanks.
            • reessi
              • Jan 2016
              • 334
              I couldn't find a firmware any where. I'll probably try buying a replacement board this eve if no other suggestions.
              Cheers
                • 12328
                • U.S.
                Probably a good call, those symptoms do seem like a mainboard issue.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Second photo, the IC below the processor, what's that in the middle of it?
                  • reessi
                    • Jan 2016
                    • 334
                    Below on the photo or below when reading the writing horizontal on the chip - the one with the heatsink?
                    cheers
                      • 12328
                      • U.S.
                      I think he's referring to the discoloration/splotch? on the IC just to the left of the Genesis chip, as you read it normally, think it says IC something 01, the one right next to where IC800 would be if there was one there.
                      • reessi
                        • Jan 2016
                        • 334
                        It's a ram chip -> HYB25DC256160CE
                        • reessi
                          • Jan 2016
                          • 334
                          There is no discoloration/splotch, it just the way the camera took the photo!
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Hdmi Ic I’ve changed a few recently.
                            • reessi
                              • Jan 2016
                              • 334
                              "Hdmi Ic I’ve changed a few recently"
                              I thought that but what about the vga? It goes straight into the main chip and all the other faults? Freezing etc?
                              Cheers.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Cheers.
                                I’ve also had ceramic surface mount capacitors and other surface mount capacitors fail on them boards too with high ESR. If you think it’s bad change it, I’ve waited months for Ics to come from Ali express it can be hit or miss. Testing can take hours too with a scope, narrow it down to the local supplies give it a check for short circuits on devices around that area.
                                • reessi
                                  • Jan 2016
                                  • 334
                                  I've ordered a main board off ebay for £13 so I'll let you know what happens. I'll have a little play with this one while I'm waiting.. Cheers.
                                  • reessi
                                    • Jan 2016
                                    • 334
                                    Replacement board came this morning in record time since I ordered at 4pm yesterday and I'm happy to report the tv is fully working.
                                    So not sure why the mainboard failed, but re-capping the PSU and a mainboard has fixed it all.
                                    Cheers.
                                    • ugamazing
                                      820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                                      by ugamazing
                                      So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                                      1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                                      2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                                      04-10-2024, 08:06 AM
                                    • flibidy
                                      Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                      by flibidy
                                      I have here a Magnum IA.100 which belongs to my parents.
                                      The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                      Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                      What Ive done........
                                      01-01-2025, 01:26 PM
                                    • N3Star
                                      ASUS ROG G15 G513QY random freezes
                                      by N3Star
                                      My laptop recently started freezing randomly - it usually freezes after a few minutes, sometimes after 2, other times 10 minutes.
                                      So far I kind of ruled out software problems, as the problem persists on live booted Linux, installed Windows and also while installing Windows. My first thought was that it was overheating, so I checked the temps and they are fine, as You can see on the screenshot, never the less I opened it up and reapplied LM on both cores, also using some more thermal putty on the VRM, obviously didn't help.
                                      While live booting Linux it usually freezes...
                                      Yesterday, 02:48 PM
                                    • howardc64
                                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                      by howardc64
                                      • Prior owner tried a replacement main board. No difference.
                                      • Samsung 2x red blinking standby LED = panel fault
                                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                      07-19-2025, 10:54 PM
                                    • kotel studios
                                      Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                                      by kotel studios
                                      Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                                      In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                                      08-06-2025, 02:07 AM
