65vl5a63db Toshiba Backlight issue
  • EliteElectronics
    • Oct 2020
    • 6
    Hi All
    I have a Toshiba (vestel cak)
    99 times out of 100 it works fine with no issues.
    Once every blue moon you switch it on and half the screen is dark. Tried an LED tester on the strips and they seem to light up every time without a problem.
    You can leave it alone and switch it on and the screen will be fine again.
    Has anyone had a really annoying intermittent fault like this before and did they manage to find what the issue was? It has had a new power board in it and it worked fine for over a week until switching it on one day and the dark half re-appeared. If it was getting knocked or moved I could understand a dodgy LED connector may be at fault but this seems to be completely random.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: 65vl5a63db Toshiba Backlight issue
    If you turn the baclights down (not contrast or brightness) to a minimum does it resolve the issue.
    • EliteElectronics
      • Oct 2020
      • 6
      Thanks for the tip. Will give it a try and see how it gets on.
      • Cornito
        Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
        by Cornito
        Hello Team,
        I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
        Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
        Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
        08-08-2024, 08:09 AM
      • cheebster
        iPad Pro 12.9 5th Gen Backlight Issue
        by cheebster
        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
        Anyone...
        05-20-2025, 09:17 AM
      • howardc64
        Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
        by howardc64
        TV was fixed just after removing Samsung's rear snap cover.
        This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
        Maybe PSU->backlight connector didn't have a good contact?...
        07-23-2025, 12:34 AM
      • roman728
        iMAC A1418 Backlight issue
        by roman728
        Hello friends,
        I have this unit with no backlight on screen. After inspection i determined there is a shorted capacitor on BKL_BOOST circuit. I removed the capacitor, short is gone but backlight still not working. I found that Q9702 is not open and R9721 is only around 70kOhms but according to schematics it should be 301k. I removed the resistor and connected the gate of Q9702 directly to GND. Now i have 12v passing by the mosfet to turn on backlight IC LP8561 (U9700) but BKL_BOOST circuit is not working. I can measure only 12V there but it should be around 60V.
        Can you...
        04-10-2025, 11:48 AM
      • bstewara
        Samsung un65eh6000 backlight issue
        by bstewara
        Hi All,
        I have a Samsung Un65eh6000 with a backlight issue.
        The original issue was backlight current was present but led strips did not light
        I tested the backlights and all tested to be working properly.
        I assumed then that the power supply was not sending current to the led strips.
        Power supply board part number BN44-00560A.
        After checking voltages it appears that current output at connector CNL802 was outputting the correct current 189 VDC on pins 1,2,6, and 8.
        The issue then was there was no ground on the connector...
        02-17-2023, 03:32 PM
