Lg 50pb 560b .
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    Lg 50pb 560b .
    This plasma tv when powered up will flash the screen light like the tv want to on and off nothing happens again. Anyone solution Please
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Lg 50pb 560b .
    Do you have a digital multimeter ?
    • ekozeko333
      by ekozeko333
      🧠 What I’ve Done So Far
      Flashed...
      06-21-2025, 02:48 AM
    • corrize
      Nikon D800 camera - flash don’t work and capacitor don’t charge
      by corrize
      Hello, I'm stuck in troubleshooting…
      The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
      In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
      When I press the flash button, it's detected by the system, flash icon appear on LDC display....
      10-01-2022, 10:02 AM
    • spmetroil
      Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
      by spmetroil
      I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
      The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
      I have a CH341A programmer and I already attempted the following steps:
      1. Identified the correct chip (W25Q128, 3.3V SPI flash).
      2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
      3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
      08-19-2025, 09:23 AM
    • abajor
      Canon VIXIA HF S10 A read data from inernal flash memory.
      by abajor
      Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
      Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
      The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
      I think my best shot is to figure out a way to read the internal flash memory outside...
      07-20-2024, 12:04 AM
    • Ihandyrepair
      4 red flash led 65X950G boot Sony and android logo but then black
      by Ihandyrepair
      HI guys
      I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
      here is the issue
      I have Sony and android logo. but then 4 led red flash lights front of the tv
      I have 3.3v ref. 12v reg then T con 12v when I press the power on button
      but then I get black screen and 4 red flash light at the front LED
      but I get 3 led flash on the LED driver board.
      I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
      so I tried...
      07-11-2024, 01:45 AM
