samsung ue55ks7000u vertical lines
  • pep2k21
    • Dec 2020
    • 35
    • Spain
    hello.
    thinking about panel or tcon, i open and foud that theres no tcon board,
    surprised, closed again, so fault must be in panel right?
    all botom flex that goes to screen seem ok but there is no difference on screen when i touch/press them.
    you have some pictures here
    there is no magic tape-cut fix for this one or something similar?
    • 12323
    • U.S.
    Re: samsung ue55ks7000u vertical lines
    You can still unhook one ribbon cable at a time going from mainboard to the panel driver board, plug tv in turn it on see what you have on display then do the other one.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4542
      • Italy - Milan
      probably cracked corner..
      • pep2k21
        • Dec 2020
        • 35
        • Spain
        i did with the flex at the top and backligth was like triying to light but not working properly...
        then unplugged and tv did not started anymore pluging but did presing start phisical key.
        • pep2k21
          • Dec 2020
          • 35
          • Spain
          but i can not see anything broken
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4542
            • Italy - Milan
            A repair man have told me yesterday the same until he have posted a photo of a corner and i have seen clearly the broken piece..
            • Falki
              Colorful LCD Vertical Lines on Samsung ue55es8090
              by Falki
              Hello there, ive recently found an older 55inch Samsung SmartTV.
              A similar issue has been posted as well but also with no actual response ...
              08-12-2025, 04:19 AM
            • Stanley1843
              by Stanley1843
              06-29-2024, 11:54 AM
            • pni
              LG 49uf695v vertical coloured lines
              by pni
              Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
              11-14-2025, 03:15 AM
            • x_orange90_x
              Samsung UN46C8000XFXZA vertical bars/horizontal lines
              by x_orange90_x
              I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
              The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
              09-04-2023, 12:09 PM
            • polaro
              Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
              by polaro
              Greetings,
              I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
              08-27-2022, 08:46 AM
