Lg 60UF7300-UT Display Concern
  • whiz62
    whiz62
    • Dec 2013
    • 242
    • usa
    Picked this up today probably should have known better. Will show pic of screen when I got it home. Took back off and saw a red wire from the PSB disconnected as if it had been pulled out of the harness connector as the pin connector was still in the harness connector that goes to the T-Con. That pin connector is labeled SCLK, ( serial clock)? Anyway it made no difference when connected.
    I know this TV has major concerns with the Main board. I have all the power board voltages and it fires right up and that is all she does. Got the 12 volts to the T-Con. Disconnected each ribbon cable to the LCD and they alternated from white on side and black on the other. Anyone have an idea on this?
    • 12140
    • U.S.
    Re: Lg 60UF7300-UT Display Concern
    Need better FOCUSED pics. of each board and one of the whole back as to see how they are all connected.
    • whiz62
      whiz62
      • Dec 2013
      • 242
      • usa
      Nomoresonys, Hope these pics are good enough.
        • 12140
        • U.S.
        Check P201: Test the voltages at the connector on the powerboard with EVERYTHING hooked up, it's the connector that the cable from powerboard to mainboard hooks into, most times there's a legend/map nearby that gives the expected voltages, you measure them with your mutimeter, set meter to 20 vdc then report them, put neg probe on chassis metal ground, pos probe on pin of connector, measure in standby take note, leave probes where they are then power on tv and again take note of voltages, report them here, example pin 1-ps-on-0 volts standby-power on-3.3 volts.
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Where is the red/pink wire connected to in your first photo of the power supply?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4316
            • Italy - Milan
            check white fuse on tcon.
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              missed out "going"
              • whiz62
                whiz62
                • Dec 2013
                • 242
                • usa
                It appears it goes to sclk pin which is second from from top because there is a connector pin still in the plug connector.
                • whiz62
                  whiz62
                  • Dec 2013
                  • 242
                  • usa
                  Fuse good, 12v on both sides.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4316
                    • Italy - Milan
                    sorry you already told it.. seen the hands already put in i suspect wrong mainboard model..
                    • whiz62
                      whiz62
                      • Dec 2013
                      • 242
                      • usa
                      With TV plugged in not turned on: With TV turned on:
                      Sin=0v Sin=.043v
                      Sclk=0v Sclk=.029v
                      Gnd=v Gnd=.004v
                      24v=0v 24v=25.02v
                      24v=0v 24v=25.02v
                      Gnd=0v Gnd=.004v
                      12v=0v 12v=11.82v
                      12v=0v 12v=11.82v
                      12v=0v 12v=11.82v
                      Gnd=0v Gnd=.004v
                      3.5v=3.5v 3.5v=3.5v
                      3.5v=3.5v 3.5v=3.5v
                      P-Dim=.005v P-Dim=2.639v
                      Pwr_on=0v Pwr_on=3.530v
                      vsync=0v vsync=.018v
                      Gnd=0v Gnd=0v
                      N.C.=0v N.C.=0v
                      Gnd=0v Gnd=.003v
                      24v=0v 24v=25.01v
                      24v=0v 24v=25.01v
                      Gnd=0v Gnd=.003V
                      12v=0v 12v=11.82v
                      12v=0v 12v=11.82v
                      Gnd=0v Gnd=.004v
                      3.5v=3.5v 3.5v=3.5v
                      Gnd=0v Gnd=.004v
                      P-Dim2=.005v P-Dim2=1.718v
                      Drv_on=.002v Drv_on=3.487v
                        • 12140
                        • U.S.
                        What all sources have you tried hdmi, rca, over the air antenna?
                        • whiz62
                          whiz62
                          • Dec 2013
                          • 242
                          • usa
                          I can't get anything on screen but the 10" wide white strip in the middle of the screen and black top and bottom. Remote only turns unit on and off.
                          • Tomylee
                            No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                            by Tomylee
                            Sorry for the person who’s going to read all this !
                            I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                            While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                            During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                            07-11-2025, 11:52 AM
                          • 5mall5nail5
                            Help identifying connector for ASUS 4090 Strix RGB LED connector
                            by 5mall5nail5
                            Hi All -
                            I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
                            Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
                            05-04-2025, 07:47 AM
                          • bussincaps
                            MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
                            by bussincaps
                            Hello All,
                            tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
                            Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
                            eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
                            Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
                            I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
                            08-03-2023, 12:57 PM
                          • michhak
                            Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
                            by michhak
                            Hi guys,
                            i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
                            It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
                            11-17-2021, 05:45 AM
                          • m1ch43lzm
                            70mai Dash Cam A510 - help identifying connector on camera module
                            by m1ch43lzm
                            Hi everyone
                            I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
                            The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
                            I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
                            05-11-2025, 06:02 PM
