Samsung UN55J6200AFXZA Lost picture and sound.
  • RAD5
    • Apr 2021
    • 7
    • us
    Some red, blue, green color lingered near the center of the screen for two seconds. Fuse on power board OK. Replaced power board and it did not solve my problem. Did flashlight test and I can see an image on the screen. What else beside power board could cause loss of picture and sound at the same time?
  • neilc6
    • Nov 2015
    • 1550
    Re: Samsung UN55J6200AFXZA Lost picture and sound.
    If you have no backlights, you likely have bad backlights. https://techhometravel.com/lg-ln-ser...ed-backlights/
    • RAD5
      • Apr 2021
      • 7
      • us
      Would the sound fail at the same time the back light fails?
      • neilc6
        • Nov 2015
        • 1550
        You need to fix one problem at a time. Audio is totally unrelated to the backlights. There are a lot of reasons for no sound - volume set to 0, muted, wrong input, audio set to external. You need to get the backlights working first.
        First test for Samsungs is to disconnect the cable between the main and power supply boards and plug the TV in. Backlights should come on.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4542
          • Italy - Milan
          can you tell me in other words?
          • RAD5
            • Apr 2021
            • 7
            • us
            neilc6-- Thanks for the insights. Backlights do not come on when main board is disconnected from power board. I get the same result with original powerboard and the replacement power board I ordered. You stated audio and back lights are unrelated but because both audio and backlights went out at the same instant after TV was on for half an hour, I tend to think that it was only one thing which failed in that instant. I checked to make sure it was not a failure of wall current to the TV.
            • RAD5
              • Apr 2021
              • 7
              • us
              Davi.p-- The color which lingered near the center of the screen very briefly reminded me of three paisley or tear drop shapes wrapped around each other.
              • nomoresonys
                • 12331
                • U.S.
                Test the voltages at the connector on the powerboard with EVERYTHING hooked up, it's the connector that the cable from powerboard to mainboard hooks into, most times there's a legend/map nearby that gives the expected voltages, you measure them with your mutimeter, set meter to 20 vdc then report them, put neg probe on chassis metal ground, pos probe on pin of connector, measure in standby take note, leave probes where they are then power on tv and again take note of voltages, report them here, example pin 1-ps-on-0 volts standby-power on-3.3 volts.
                • nomoresonys
                  • 12331
                  • U.S.
                  Are you getting voltage on CNM803 pins?
                  • nomoresonys
                    • 12331
                    • U.S.
                    Check the voltage on J832.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4542
                      • Italy - Milan
                      Mmmmh, i don't know the word lingered but clearly you are trying to describe me the start of an animated logo at power up. But protection takes place because of a led lamp problem. You can build a very primitive B.L. tester with a diode bridge, a cable, a power resistor or some. YTube is full of those schemes. So you can test the strips without open screen, by the first, then you dismantle it if BL is KO
                      • RAD5
                        • Apr 2021
                        • 7
                        • us
                        At CNM803, I can access pins 1,3,5,7,9. On standby, pins 1,3,5,7 read 11.15 volts. Pin 9 reads zero. With TV powered on, pins 1,3,5,7 read 12.76 volts and pin 9 reads zero. At J832, I read 11.15 volts in standby and 12.76 with TV on.
                        • nomoresonys
                          • 12331
                          • U.S.
                          Very carefully check the voltage of CP810S, meter set to 600 vdc, careful what you touch this is the HOT/DEADLY side of the powerboard, with a probe on each leg what voltage do you get? Check it in standby which is powered off and when powered on, when powered on should prolly be around 400 volts if this checks ok, next I would take powerboard out and inspect the solder joints real closely and re-flow any that look suspect, google images is your friend for how bad joints look if needed. Thats just 2 easy tests, it probably is bad backlight/s, be very careful if you have to tear it down to backlights these sammy UN models are tricky, watch a least a few how to youtube videos to get the gist of it, oh and the panels are VERY flimsy and easy to break too.
                          • RAD5
                            • Apr 2021
                            • 7
                            • us
                            I checked voltage at CP810S on both the old power board and the replacement power board I installed. Voltage for both boards was about the same 165 on standby and 390 when powered on. I did not see any suspect solder joints. If it is a backlight problem, would failure of one LED make all of them go out? Would backlight failure cause the loss of sound at the same instant? Thanks
                            • TR103
                              by TR103
                              - it keeps rebooting
                              01-22-2025, 04:12 PM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • Ierwin
                              by Ierwin
                              05-13-2025, 03:31 PM
                            • jchang
                              Samsung UN70NU6900F no picture and no sound
                              by jchang
                              Hi all
                              I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                              Symptom:
                              No picture no sound.
                              When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                              No sound at all.
                              What I tried:
                              1. I tried unplugging the left or right ribbon...
                              01-09-2023, 06:28 PM
                            • AlanP64
                              Samsung UN55J6200AFXZA Sound but no Picture
                              by AlanP64
                              As title states, sound but no picture. I have done all of the rudimentary troubleshooting steps- flashlight test no lights visable. Checked Source and it is correct. Tried different, verified good HDMI cable, swapped satellite receiver boxes etc and no luck. I see lots of kits with replacement boards, but before I start throwing parts at it I'd like to know if anyone has suggestions. The brown power board has a couple of spots that are suspect. They are a darker brown circular color. Not sure if that is just from normal use or if something may be burnt. Not sure if a suspect power board is capable...
                              10-10-2022, 02:38 PM
