Acer AT3201W sound no video
  • rb0746
    • Jan 2010
    • 42
    Okay I picked this set up for 15.00 thought it would be a good set to practice on. I have limited knowledge when it comes to this type of thing but, I am a very willing student when it comes to learning.
    (the acer logo appears for a second then to black screen for all the below tests)
    I get this Acer AT3201W home and I plug it in do the usual hook up different audio/video to the various inputs. Same result audio is fine no video.
    No obvious caps bulging,nothing looks burnt or shorted so I focus in on the inverter board. I measure all primary and secondary on the transformers. I
    find that one of the s2 has a reading of 0 so I have removed this transformer and waiting on the replacement to come in.
    Question
    Should I be checking anything else while I wait ?
    also I would like to check the voltage going to this board but I do not have the schematics so I have no idea what point to test any ideas ?
    BTW this is a great site lots of knowledgeable people here I have learned so much following some of the different threads here
    thanks again
    Ron
    I will upload photos shortly the system is not allowing me to upload at this time .
    Cheers
    Ron
    When I told my doctor I broke my leg in two places while carrying a big Monitor, he told me to stop going to those places.
  • rb0746
    • Jan 2010
    • 42
    Re: Acer AT3201W sound no video
    Here are a couple pics of the Acer 3201W
    Cheers
    Ron
    • rb0746
      • Jan 2010
      • 42
      Here is a photo of the power supply
      Cheers
      Ron
      • PlainBill
        • Feb 2009
        • 7034
        Question
        thanks again
        Ron
        What resistance range did you use to measure the secondaries? By the picture I notice that one transformer appears to be missing. Did you check the suspect out of circuit?
        There's not much else to test. Transformers in inverters fail all the time, so there is no point in going beyond this to find a cause.
        PlainBill
        • rb0746
          • Jan 2010
          • 42
          Thanks for the reply PlainBill .
          yes I did test out of circuit with the same result of 0 .
          inverter transformers (results)
          1 s1 881 s2 878
          2 872 869
          3 871 867
          4 882 878
          5 892 887
          6 886 0
          7 919 917
          8 890 885
          Cheers
          Ron
          • PlainBill
            • Feb 2009
            • 7034
            1 s1 881 s2 878
            2 872 869
            3 871 867
            4 882 878
            5 892 887
            6 886 0
            7 919 917
            8 890 885
            Looks to me the only problem you are going to have with your $15 'practice TV' is you aren't going to be getting a lot of practice. Good work!
            PlainBill
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              looks like a darfon v144.
              you nailed the bad transformer.common failure.
              • rb0746
                • Jan 2010
                • 42
                Hopefully that's the only problem. I will let you know when the new transformer is installed.
                Cheers
                Ron
                Cheers
                Ron
                • rb0746
                  • Jan 2010
                  • 42
                  Re: Acer AT3201W sound no video (SOLVED)
                  Well the transformer came in today and I eagerly soldered it in place .
                  Everything is working fine now for the last couple hours.
                  Thanks again to all that helped !.
                  Now I need to find another set to learn on .
                  Cheers
                  Ron
                  • Wizard
                    • Mar 2008
                    • 2296
                    RB0746 where do you get this transformer?
                    Cheers, Wizard
                    • rb0746
                      • Jan 2010
                      • 42
                      Cheers, Wizard
                      Moniserv.inc
                      www.lcdparts.net
                      Cheers
                      Ron
                      • Wizard
                        • Mar 2008
                        • 2296
                        Thank you, rb0746.
                        Cheers, Wizard
                        • mdc66
                          • Apr 2010
                          Hi Guys. I have a Acer AT3201W with near the same problem. Acer Logo, then black screen and lots of sound.
                          Measured the transformers, but they all have the same measurement in comparison, and seem to be okay. Could there be a PSU outage fault?
                          How come the logo screen comes on if there is a fault?
                          Taa, thanks a lot
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Taa, thanks a lot
                            There are many causes for the 'two seconds to black' problem. Search, read, troubleshoot, fix.
                            PlainBill
                            • ccbee747
                              • May 2010
                              Hello MDC66, I have got the same problem you have, I found a faulty 2005D on the inverter pcb, I replaced it but the screen still only powers up for about one second then back to black screen, before I fitted the new transformer the TV would not power up, I have spent hours online looking for a circuit diagram for this TV but had no luck yet, I've emailed Acer and Delta Electronic of china and had no response from them at all, not a very good way to run a company, seems once they have your money you can go whistle for all they care, so now I'm going to research all the semiconductors on the PSU, I think the problem might all be down to the IC which controls the power up and stand by function, I will keep you posted when I find the fault, if anyone reading this has any other ideas where to look for the fault please let me know, thanks for reading this.
                              • kp47
                                • Sep 2011
                                hi everyone i am a new user and i just finish my electronic.
                                pleas any one let me know where is located RB0746.
                                kp47
                                • shalzi
                                  • Oct 2011
                                  hi i have a at3201w tv that doesnt show a acer sign when turned on or anything if i press the source button the screen colour changes but no menu or anything is desplayed the sound works but thats about it can someone please help really want to get this working again
                                  • hummer59
                                    • Dec 2011
                                    Hello everyone...this column has been great for help narrowing down a similar problem with my at3201w. Initially I had the 2 second Acer logo then the unit would shut off and remain in standby mode....needing a hard reset with power switch....replaced the inverter board. That solved the backlight issue...
                                    Now the issue is when you turn it on with remote or by button....picture comes on....but buttons do nothing until you hard reset again with power switch on the back. Then t.v. works fine.....so I replaced the power board....same problem.
                                    So now i'm down to the main board....
                                    I don't have very much experience switching out bad caps and doing tests on them, so any help would be appreciated. I know just enough to be dangerous!
                                    • hummer59
                                      • Dec 2011
                                      Okay...took the plunge after reading the how to's and now....I have a t.v. that works!!! Thanks!!1
                                      • soeren
                                        A2442 - No sound over internal speakers and no video playback
                                        by soeren
                                        I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                                        All happened after the battery ran out of power overall several days when I was on vacation.
                                        I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                                        07-26-2024, 01:24 AM
                                      • JRade
                                        Audio video receiver KENWood KR-V990D,no sound
                                        by JRade
                                        When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                                        The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                                        I replaced the capacitor C303/0.047F, nothing changes.
                                        I'm asking for help, what should I do next?
                                        Thanks in advance!...
                                        08-05-2025, 10:23 PM
                                      • FrancescoV
                                        Onkyo HT-R390 no sound output, video output ok
                                        by FrancescoV
                                        Good morning everyone,
                                        I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                        The firmware reported is the following:
                                        M:1.00/11107BLP
                                        D:?.??/????????
                                        O:1.00/11107AL
                                        The DSP firmware given the question marks seems corrupt.
                                        On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                        05-11-2025, 02:59 AM
                                        Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                        This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        09-07-2024, 05:00 AM
                                        Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                        This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
