philips 32pfl3258h/12 no picture
  • filippia1981
    • Mar 2021
    • 29
    • Greece
    I have this TV. I have changed the psu board with a new one but I still do not get standby light or any kind of response.
    backlight is ok and tested with BL tester. the issue I think is on mainboard.
    what should I do?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: philips 32pfl3258h/12 no picture
    Post pictures of your circuit boards and give any voltage readings you have taken.
    • filippia1981
      • Mar 2021
      • 29
      • Greece
      All the voltages ta psu are there:
      12V, 24V, 3.2V ps_on,
      the backlights work because they are tested by tester
      • filippia1981
        • Mar 2021
        • 29
        • Greece
        I dont get any voltages at tcon
        • filippia1981
          • Mar 2021
          • 29
          • Greece
          where can I also find the firmware of this tv?
          • yokoono
            • Apr 2010
            • 505
            The command to turn on the stb LED is given by the processor. The command for powering the t-con with 12v is given by the whole processor.
            • kasfamily
              • Aug 2014
              • 774
              • Russia
              firmware
                • 12276
                • U.S.
                Elaborate, "I dont get any voltages at tcon" No voltage coming in from mainboard, getting to tcon fuse, leaving tcon fuse or going to panel?
                • filippia1981
                  • Mar 2021
                  • 29
                  • Greece
                  I dont get the 12V on the tcon fuse and at the lvds cable from main to tcon I dont see any voltages apart from 3.3V.
                  • filippia1981
                    • Mar 2021
                    • 29
                    • Greece
                    Thanks for the firmware
                    • Rauni
                      Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                      by Rauni
                      Hello, this is my first post on this forum, and my first attempted to repair a TV.
                      My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                      Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                      Read also that we should test what happens if we...
                      10-01-2023, 12:06 AM
                    • Schwoin
                      Philips 243v5lhsb00 Monitor Picture too bright
                      by Schwoin
                      Hey everyone,
                      the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                      While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                      you can see them on the top half of the photo.
                      At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                      03-21-2023, 12:40 PM
                    • madyoyo
                      Philips 37pfl560: Yellow picture
                      by madyoyo
                      HI.
                      I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
                      Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
                      05-30-2025, 10:16 AM
                    • charlesdutcher
                      No picture issue in Philips Chassis FTL2.1
                      by charlesdutcher
                      My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
                      Is there someone having any symptom like this? How to fix it?
                      Thanks in advance!​
                      08-06-2024, 09:55 PM
                    • triplefour
                      by triplefour
                      09-13-2023, 10:43 PM
