SSooooo i picked up a 65inch vizio that someone was throwing away so i figured i would try and fix. seemed simply enough but after i got it back together it is not turning on. i have power coming from the power supply to the main board but nothing going into the tcon. i had the tv on a bed while i was working on it...could i have fried it from static maybe?? Thanks in advance!!
Vizio E65-E3 Dead after backlight replacement
Re: Vizio E65-E3 Dead after backlight replacement
Test the voltages at the connector on the powerboard with EVERYTHING hooked up, it's the connector that the cable from powerboard to mainboard hooks into, most times there's a legend/map nearby that gives the expected voltages, you measure them with your mutimeter, set meter to 20 vdc then report them, put neg probe on chassis metal ground, pos probe on pin of connector, measure in standby take note, leave probes where they are then power on tv and again take note of voltages, report them here, example pin 1-ps-on-0 volts standby-power on-3.3 volts.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS. -
So it was apart when you picked it up or you did some work on it?Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
but after i got it back together it is not turning on.Willing to help but I'm no expert.Comment
When i picked it up, one side of the display was dim...like the leds were bad. after i opened it up and tested them, 1 out of every led strip (there are 12) had a bad led. so i ordered a new set, tested those to make sure they all work, and installed them.Last edited by a460guy; 04-03-2021, 09:29 AM.Comment
You may have a bad led connector connection problem (as in a bad joint) or at any one of the interconnection between led strips.
Have a look at https://www.youtube.com/watch?v=-GC5AwZCsF4Last edited by dick_barton; 04-03-2021, 12:28 PM.Willing to help but I'm no expert.Comment
So at this point I would be testing the voltages on each pin of the led connector at switch on. Does it peak and then drop and what are the min/max values.Last edited by dick_barton; 04-04-2021, 05:17 AM.Willing to help but I'm no expert.Comment
Tested at the connector on main board going to leds.. pins 1 - 14..voltages fluctuate before settling around -.030.
Pins 17-24 all just drop to -.007 in a few seconds after power on.
I have a hot air station ariving in the mail today and will try the bga suggestion.Comment
When doing backlight replacements, I always turn the TV on with the panel disconnected to confirm they are lighting up before reassembly. Also check after installing the diffuser panels to check for dirt or debris and to check if the backlight is even.Comment
Very carefully check the voltage of C2, meter set to 600 vdc, careful what you touch this is the /HOT/DEADLY side of the powerboard, with a probe on each leg what voltage do you get? Check it in standby which is powered off and when powered on, when powered on should prolly be around 400 volts if this checks ok, next I would take powerboard out and inspect the solder joints real closely and re-flow any that look suspect, google images is your friend for how bad joints look if needed.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Looks like youre not getting the boosted pfc, check all diodes on powerboard and don't forget to check those solder joints.Last edited by nomoresonys; 04-15-2021, 10:33 AM.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
Assuming...7 Photos -
by bstewaraHi All,
Has anyone had the experience of replacing backights on the “P” series Vizio tv?
Model number P659-G1
This type tv has a very small bezel holding the screen in and I’m not sure how the bezel/screen is assembled. ( I’m hoping the screen is not epoxied to the frame)
Before I attempt this I thought maybe someone on this forum has performed this backlight replacement procedure.
Thanks in advance... -
by double_DDHi guys,
I have a dead coffee machine, and it seems that the culprit (no 1, at least) is a dead trafo - primary coil seems to be blown open (type shown on the picture below).
Now, I'm unable to find direct replacement anywhere on ebay or aliexpress, and all similar that I' was able to find are rated too low (<1A).
If someone knows a shop to buy replacement (EU/CH), that would of course be my 1st option.
My other ideas:
- to buy 220/20Vac trafo with 30VA, and to "manually" create secondary 12V output just via resistor
- to buy... -
by YanlebI have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've... - Loading...
