Vizio E65-E3 Dead after backlight replacement
  • a460guy
    • Oct 2013
    • 59
    • it's
    SSooooo i picked up a 65inch vizio that someone was throwing away so i figured i would try and fix. seemed simply enough but after i got it back together it is not turning on. i have power coming from the power supply to the main board but nothing going into the tcon. i had the tv on a bed while i was working on it...could i have fried it from static maybe?? Thanks in advance!!
    • 12306
    • U.S.
    Re: Vizio E65-E3 Dead after backlight replacement
    Test the voltages at the connector on the powerboard with EVERYTHING hooked up, it's the connector that the cable from powerboard to mainboard hooks into, most times there's a legend/map nearby that gives the expected voltages, you measure them with your mutimeter, set meter to 20 vdc then report them, put neg probe on chassis metal ground, pos probe on pin of connector, measure in standby take note, leave probes where they are then power on tv and again take note of voltages, report them here, example pin 1-ps-on-0 volts standby-power on-3.3 volts.
    • a460guy
      • Oct 2013
      • 59
      • it's
      Here are the results....when on pin 1 goes back and forth from -.002 to .001. Thanks for the quick response!
        • 12306
        • U.S.
        So it was apart when you picked it up or you did some work on it?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          So initially it was turning on and what was working. Power on led, backlights, image ?
          • a460guy
            • Oct 2013
            • 59
            • it's
            When i picked it up, one side of the display was dim...like the leds were bad. after i opened it up and tested them, 1 out of every led strip (there are 12) had a bad led. so i ordered a new set, tested those to make sure they all work, and installed them.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              You may have a bad led connector connection problem (as in a bad joint) or at any one of the interconnection between led strips.
              Have a look at https://www.youtube.com/watch?v=-GC5AwZCsF4
              • a460guy
                • Oct 2013
                • 59
                • it's
                I pulled the connector from the main board and fired each strip. They are all pulling the same 32.4 volts so they are all working. Any more ideas?
                • alfatv
                  • Sep 2020
                  • 353
                  Could be bad solder joints at main board BGA. Remove heatsink and blow some hot air when TV is off. Wait until it cools down and turn it on. This is not a fix, just troubleshooting technique.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    So at this point I would be testing the voltages on each pin of the led connector at switch on. Does it peak and then drop and what are the min/max values.
                    • a460guy
                      • Oct 2013
                      • 59
                      • it's
                      Tested at the connector on main board going to leds.. pins 1 - 14..voltages fluctuate before settling around -.030.
                      Pins 17-24 all just drop to -.007 in a few seconds after power on.
                      I have a hot air station ariving in the mail today and will try the bga suggestion.
                      • a460guy
                        • Oct 2013
                        • 59
                        • it's
                        Update.....tried hot air on main board bga...no difference. replaced main board and am still getting nothing... what should i try next?
                        • a460guy
                          • Oct 2013
                          • 59
                          • it's
                          Pics
                          • neilc6
                            • Nov 2015
                            • 1550
                            Does it attempt to turn on? Try connecting only one side at a time between the tcon and panel and see if the TV turns on with half a screen.
                            • a460guy
                              • Oct 2013
                              • 59
                              • it's
                              I put a flashlight to the screen and turns out there is image! So now i just need to figure out why the new led s are not coming on.
                              • neilc6
                                • Nov 2015
                                • 1550
                                When doing backlight replacements, I always turn the TV on with the panel disconnected to confirm they are lighting up before reassembly. Also check after installing the diffuser panels to check for dirt or debris and to check if the backlight is even.
                                  • 12306
                                  • U.S.
                                  Very carefully check the voltage of C2, meter set to 600 vdc, careful what you touch this is the /HOT/DEADLY side of the powerboard, with a probe on each leg what voltage do you get? Check it in standby which is powered off and when powered on, when powered on should prolly be around 400 volts if this checks ok, next I would take powerboard out and inspect the solder joints real closely and re-flow any that look suspect, google images is your friend for how bad joints look if needed.
                                  • a460guy
                                    • Oct 2013
                                    • 59
                                    • it's
                                    19.5v during stand by and 19v at power on at c2
                                    • a460guy
                                      • Oct 2013
                                      • 59
                                      • it's
                                      No sorry....... its 170vdc on stand by and 164vdc at power on
                                        • 12306
                                        • U.S.
                                        Looks like youre not getting the boosted pfc, check all diodes on powerboard and don't forget to check those solder joints.
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • bstewara
                                          Vizio P659-G1 Screen Removal / Backlight Replacement
                                          by bstewara
                                          Hi All,
                                          Has anyone had the experience of replacing backights on the “P” series Vizio tv?
                                          Model number P659-G1
                                          This type tv has a very small bezel holding the screen in and I’m not sure how the bezel/screen is assembled. ( I’m hoping the screen is not epoxied to the frame)
                                          Before I attempt this I thought maybe someone on this forum has performed this backlight replacement procedure.
                                          Thanks in advance...
                                          09-26-2022, 10:40 AM
                                        • double_DD
                                          Transformer replacement for a dead coffee machine
                                          by double_DD
                                          Hi guys,
                                          I have a dead coffee machine, and it seems that the culprit (no 1, at least) is a dead trafo - primary coil seems to be blown open (type shown on the picture below).
                                          Now, I'm unable to find direct replacement anywhere on ebay or aliexpress, and all similar that I' was able to find are rated too low (<1A).
                                          If someone knows a shop to buy replacement (EU/CH), that would of course be my 1st option.
                                          My other ideas:
                                          - to buy 220/20Vac trafo with 30VA, and to "manually" create secondary 12V output just via resistor
                                          - to buy...
                                          06-23-2025, 05:43 AM
                                        • Yanleb
                                          Vizio M70-D3 4K with dark spots backlight issue
                                          by Yanleb
                                          I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
                                          On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
                                          I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
                                          03-22-2022, 01:06 AM
