Vizio E65-E3 Dead after backlight replacement
  • Diah
    • Feb 2013
    • 6460
    Re: Vizio E65-E3 Dead after backlight replacement
    you call them new LED.. if they really new.. can you show me the old one how its socket... some strings each have different layout. so the assamply going wrong.
    • a460guy
      • Oct 2013
      • 59
      • it's
      checked all diodes....re flowed all the bigger joints that looked dull in color. still nothing. on the back of the power board there is what looks like "snail trails" going around. what could that be from? next step desoldering resistors and mosfets and checking them?
      • a460guy
        • Oct 2013
        • 59
        • it's
        Pics of trails
        • a460guy
          • Oct 2013
          • 59
          • it's
          Diah.... i do not have the old strips anymore to take a pic of. But i did remove the socket at the main board and applied voltage and was able to light each strip.
          • Diah
            • Feb 2013
            • 6460
            i am afraid of you need to take the risk again to take the panel apart. lighting strips never being way to test LED BL. we talked about it many time how it light on but the ziner diode was open or shorted. you still can with out panel power on the set BL will come on too if every things correct.
              • 12306
              • U.S.
              #26
              Re-flow the iffy joint first picture bottom middle of picture, left one of the three there, see the cracks? Might not be a problem just looks a little iffy.
              • a460guy
                • Oct 2013
                • 59
                • it's
                #27
                Reflowed that one and also pulled the mosfets and they checked no short... should i be concerned about that residue stuff that around the board?
                Diah....here are a few pics of what i did to check the leds...where is this diode your talking about? I dont remember seing it on the strips or in the harness.
                • Diah
                  • Feb 2013
                  • 6460
                  each LED unit had build in ziner diode for currents forward opposite to the lit diode.
                  BTW; you wrote before you found 12 LED didn't work.. this cant be all get defect at once.
                  • alfatv
                    • Sep 2020
                    • 353
                    Tested at the connector on main board going to leds.. pins 1 - 14..voltages fluctuate before settling around -.030.
                    Pins 17-24 all just drop to -.007 in a few seconds after power on.
                    I have a hot air station ariving in the mail today and will try the bga suggestion.
                    There no power to LED's or there is open circuit based on this.
                    Check the voltages at last connector before backlights or even punch the wires.
                    It will be easier to figure it out if you remove the panel.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      #30
                      Post #3 you say
                      Pin 1 Stby = 0V, Out of standby = 0.001V
                      which is odd since normally the standby voltage goes from 0V to 3V or 3V to 0V
                      Post #11
                      Shows no voltages on the led connector pins.
                      Post #17
                      C2 voltage at standby = 170V and out of standby 164V
                      The voltage should increase I believe to around 380V and not drop
                      I think you are missing the led driver supply and may well be linked to the C2 low voltage.
                      What is the led driver IC part number. A photo of the underside of your power supply could prove usefull.
                      • a460guy
                        • Oct 2013
                        • 59
                        • it's
                        #31
                        Diah...here are acouple pics of the strips
                        • Diah
                          • Feb 2013
                          • 6460
                          unplug the socket from the strips and start testing all led by digital meter diode mode.. you have 2 points on the strips close to each LED + - with digital meter the good LED will lid on dim on one side and when you reverse the probe will read ziner diode between 0.54 -0.78
                          go thru all LEDs one by one.
                          • a460guy
                            • Oct 2013
                            • 59
                            • it's
                            #33
                            I cant make out anything on the chips...here are pics
                            • a460guy
                              • Oct 2013
                              • 59
                              • it's
                              #34
                              They all lit up dim... but all read ol in reverse...is this diode super tiny next to the led? Cuz i dont see it
                              • Diah
                                • Feb 2013
                                • 6460
                                the ziner diode are build in you cant see it
                                • Diah
                                  • Feb 2013
                                  • 6460
                                  from where you bought this strips,,, the LED on them are normal LED not For TV backlight. they are with out ziner diode.. here are your problem friend.
                                  interesting matter now.. but let us go deep with the issue..
                                  each socket you have 3 wires white / black / red.. the red one where its goes on the strips?
                                  • a460guy
                                    • Oct 2013
                                    • 59
                                    • it's
                                    #37
                                    red is postive for both strips.....white is negative for 1st strip and black is negative for the 2nd strip
                                    I bought it on Ebay! (Singing Weird-Al song)....lol
                                    • Diah
                                      • Feb 2013
                                      • 6460
                                      if you are sure that yours digital meter diode mode working or beep tone mode too.. then
                                      refund them.. they are absolute jock. TV backlight LEDs are with build in ziner diode.. normal strips for swimming pool or living room romantic view are with out this ziner LOL
                                      • a460guy
                                        • Oct 2013
                                        • 59
                                        • it's
                                        #39
                                        ....Really? Anyone second this?
                                        • alfatv
                                          • Sep 2020
                                          • 353
                                          In my opinion zener diode is not essential. You need to have current running through LEDs to produce light, that's it.
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • bstewara
                                            Vizio P659-G1 Screen Removal / Backlight Replacement
                                            by bstewara
                                            Hi All,
                                            Has anyone had the experience of replacing backights on the “P” series Vizio tv?
                                            Model number P659-G1
                                            This type tv has a very small bezel holding the screen in and I’m not sure how the bezel/screen is assembled. ( I’m hoping the screen is not epoxied to the frame)
                                            Before I attempt this I thought maybe someone on this forum has performed this backlight replacement procedure.
                                            Thanks in advance...
                                            09-26-2022, 10:40 AM
                                          • double_DD
                                            Transformer replacement for a dead coffee machine
                                            by double_DD
                                            Hi guys,
                                            I have a dead coffee machine, and it seems that the culprit (no 1, at least) is a dead trafo - primary coil seems to be blown open (type shown on the picture below).
                                            Now, I'm unable to find direct replacement anywhere on ebay or aliexpress, and all similar that I' was able to find are rated too low (<1A).
                                            If someone knows a shop to buy replacement (EU/CH), that would of course be my 1st option.
                                            My other ideas:
                                            - to buy 220/20Vac trafo with 30VA, and to "manually" create secondary 12V output just via resistor
                                            - to buy...
                                            06-23-2025, 05:43 AM
                                          • Yanleb
                                            Vizio M70-D3 4K with dark spots backlight issue
                                            by Yanleb
                                            I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
                                            On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
                                            I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
                                            03-22-2022, 01:06 AM
