Samsung TV PSU -BN44-00851B
  • gsmith413
    • Mar 2021
    • 17
    • India
    Samsung 40 inch tv powers supply board schematics needed - L40MSFN-FHS BN44-00851B
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • Nicktronic
    Samsung Power Supply Board BN44-00874F
    by Nicktronic
    Hey everyone,
    This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
    Anybody...
    03-17-2025, 06:20 AM
    After all of...
    07-13-2024, 08:14 PM
  • repair-it
    Need advice testing a samsung power supply board with scope
    by repair-it
    I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
    07-12-2025, 11:00 AM
  • Asraf Atb
    Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
    by Asraf Atb
    Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
    Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
    I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
    01-27-2025, 05:02 PM
