Service Manual xbr-65x850d
  • itelite
    • Aug 2016
    • 124
    Can anyone share the Service manual for the Sony xbr-65x850d (or xbr-55x850d)?
    I am having an issue where it powers up for about 3 seconds, screen shuts off, 6 blinks.
    Feels like a LED issue, and would like to find the backlight PWM signal to experiment with injecting a different/lower duty cycle. Nothing seems to be marked on the board and im not having enough time to get an accurate reading on a meter/scope.
    A pinout for the connector between the little power board and main board be ideal
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Service Manual xbr-65x850d
    If the attached photo is of your power supply then it does appear to have a legend for the connectors.
    • itelite
      • Aug 2016
      • 124
      I appreciate it, but thats not the same board. This is one of the XBRs that has the external DC power supply, and then it plugs into a little power distribution board.
      This little board has the 2 backlight driver ICs on it as well, but im struggling to find where those ICs are getting the PWM from.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Perhaps you could post some photo's of the boards.
        • itelite
          • Aug 2016
          • 124
          Kind of a silly but effective work around on this tv. It for sure is a LED issue.
          If you disconnect pin 2 (FAIL) on both of the backlight controller ICs, it will stop triggering the shutdown. At which point you can then go into the settings and turn down the backlight (which will of course be set to MAX). when it is set to reasonable level you can reconnect the FAIL pins and so far its been working.
          Seems like over/under voltage/current is being triggered when the ICs are blasting at full power.
          A true fix would be testing and replacing leds, but you could not pay me enough to ever do a side lit XBR again.
          Well hopefully that helps someone out in the future.
          • R_J
            • 9535
            The service manuals for these models do not have schematics, the pwm signal(s) will come from the main board
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              An interesting method. Let's hope its a long term solution.
                • 12128
                • U.S.
                Curious, what was the hardest part of the one that you did do?
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • Grouickman
                  Hofmann geodyna 6300 Wheel balancer
                  by Grouickman
                  Hi there,
                  First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
                  Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
                  I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
                  I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
                  03-31-2025, 05:29 AM
                • H34TO
                  ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                  by H34TO
                  Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                  06-17-2025, 07:17 AM
                  LCD LED TV Service Menu Codes
                  ALL LCD LED TV SERVICE MENU CODES
                  Service Menu Code with Board Name
                  China Universal Board / Jumper Board Service Menu Code
                  Changhong Ruba Service Menu Code
                  Ecostar LED TV Service Menu Code
                  Orient LED TV Service Menu Code
                  Haier LED TV Service Menu Code
                  TCL LED TV Service Menu Code
                  Samsung LED TV Service Menu Code
                  LG LED TV Service Menu Code
                  Videocon LED TV Service Menu Code
                  Supra LED TV Service Menu Code
                  Toshiba LED TV Service Menu Code
                  Symphony LED TV Service Menu Code
                  Veste/ LED TV Service Menu Code...
                  10-31-2024, 03:58 AM
