LG 50pq3000
  • bill25
    • Sep 2015
    • 40
    • Greece
    Re: LG 50pq3000
    The relay clicking all the time (every time i put the TV on) and voltages is 380v without the resistor.
    • bill25
      • Sep 2015
      • 40
      • Greece
      Re: LG 50pq3000
      The voltage on pin 5 on the IC is 4.8v
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Re: LG 50pq3000
        So the supply to the micro is fine. I don't know how you would test it since it appears to be a supervisory IC monitoring various signals to control the power supply.
        • bill25
          • Sep 2015
          • 40
          • Greece
          Re: LG 50pq3000
          It's difficult to see if it works properly but i wonder, can i change it with a new one? or is programmable from the factory (LG).
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Re: LG 50pq3000
            Being a micro I can only assume that it is pre-programmed for that set.
            • R_J
              • 9624
              Re: LG 50pq3000
              So with the power supply completely disconnected except for the ac mains, the relay continues to click when power is applied?
              The 380v would suggest the pfc is working and getting the vcc2 voltage.
              That ic701 is pre programed and not likely the problem.
              There are 3 large white ceramic resistors R957 etc. check that they are ok.
              Can you read the number on IC801?
              • bill25
                • Sep 2015
                • 40
                • Greece
                #27
                Re: LG 50pq3000
                The relay click once on start up. Resistors are good i check them first. I replace the IC801 already. (L6599D).
                • bill25
                  • Sep 2015
                  • 40
                  • Greece
                  #28
                  Re: LG 50pq3000
                  The relay click once every time, i start the TV.
                  • R_J
                    • 9624
                    Re: LG 50pq3000
                    What is the vcc voltage on Pin 12 of ic801?
                    What is the voltage on Pin 5?
                    Why was the ic replaced? was it bad or just a suspect?
                    • bill25
                      • Sep 2015
                      • 40
                      • Greece
                      #30
                      Re: LG 50pq3000
                      No its not bad l have a new one and checked.
                      Pin 5 - 0 volts
                      Pin 12 - 0 volts.
                      • bill25
                        • Sep 2015
                        • 40
                        • Greece
                        #31
                        Re: LG 50pq3000
                        If you have schematics from this PSU please upload it.
