firmware for sony KDL40X 3500
  • jimbofz
    • Apr 2013
    • 539
    #41
    Re: firmware for sony KDL40X 3500
    no s/c on pins
    over 850k to earth
    • Diah
      • Feb 2013
      • 6365
      Man. on the photo its clear there are soldering line going thru all 3 pins... need to clean them.. or did yours camera add lines on pins LOL.
      • jimbofz
        • Apr 2013
        • 539
        #43
        this is the cct that drops the 12v
        • jimbofz
          • Apr 2013
          • 539
          #44
          no that was just a bit of dust on photo sorry
          • Diah
            • Feb 2013
            • 6365
            yours T_CON the issue by dropping the 12V supply
            the soldering work on it before was not clean job.. i have doped if any can know where the issue but blowing F1 enough to judgment its fault. replace it or do clean work on it.. that no more F1 goes Open.
            • jimbofz
              • Apr 2013
              • 539
              #46
              ok thanks ,
              did you consider the cct i posted with regards to 12v line being pulled down by this fet? when linked i/p to o/p 12v comes up and pic is fine
              there is no sign of any component getting hot on t con with this linked
              the reason that the fuse failed was tha foil was shorting pins out ,
              and that was sorted when i replaced the foil
              as you can see in previous post ,pic is good and t con no sign of overheating even without its heatsink fitted
              • Diah
                • Feb 2013
                • 6365
                Originally posted by jimbofz
                ok thanks ,
                foil...?? which one? do you mean ribbon cable ?
                • Diah
                  • Feb 2013
                  • 6365
                  i see, i saw it at yours other threat ( ribbon cable )... this will not change the suspect.. if F1 goes open because of shorts pins. mean another parts effected either on the panel edge boards so ( now if you put in place F1 it will open again ).. follow the lines which were shorted. start from the panel edge boards. dont guess yours calculation on perfect picture or no heat.. it need really deep inspection from end boards ( panel ) forward the T-CON self.
                  • jimbofz
                    • Apr 2013
                    • 539
                    #49
                    ok will give that a try
                    • tec3000
                      Sony LED 65X9005A shuts down after few seconds - looking for help
                      by tec3000
                      Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                      I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                      03-20-2024, 07:29 AM
                    • joby91
                      SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
                      by joby91
                      I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
                      I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
                      I found one chat about firmware on ************** forum but i cannot read the comments.
                      https://**************/forum/108-114100-1#880537
                      09-04-2024, 01:34 PM
                    • jason123
                      Sony Firmware for XBR-70X850B
                      by jason123
                      Hello
                      Help is much appreciated. I have a Sony XBR-70X850B with bad main board. I got a mainboard for it, but as you know I have to update the firmware on this TV for the main board to work.
                      I went to the Sony website, and I can't seem to find the Firmware file. Sony is no longer making this available.
                      Does any of you have firmware / software files for this TV that I can put on USB for update to make this main board work?
                      Much appreciated.
                      05-17-2022, 12:42 PM
                      HP Pro 3500 Pro 3500 G540 Specification for Upgrade or Repair
                      This specification for the HP Pro 3500 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro 3500 boardview and Pro 3500 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP Pro 3500 is accurate,...
                      09-12-2024, 03:36 PM
                      HP Pro 3500 Pro 3500 G2020 Specification for Upgrade or Repair
                      09-12-2024, 03:30 PM
