how often are bad capacitors responsible for LED monitor failures?
  • xeos
    • Apr 2014
    • 38
    • usa
    I've had great luck repairing computer monitors and LCDs made in the 2000s when CFL backlights were the only option. In most cases it was easy to see leaking capacitors on the power supply and replace them, and at least 5 out of 6 displays were fixed successfully this way. I've recently taken apart a couple LED backlit TVs, expecting to continue my success, only to find capacitors that look completely fine. Is it still worth trying replacing them? Or are LED TVs, because of their lower power demands, no longer killing power supplies (or maybe caps have gotten a lot better)?
    sorry if this is answered elsewhere. I've read the getting started guides.
  • nomoresonys
    • 12269
    • U.S.
    Re: how often are bad capacitors responsible for LED monitor failures?
    Since the average lifespan of an electrolytic cap is 10 years, any that age or older are always suspect, check out the sneaky bad caps that NorCal found here:
    https://www.youtube.com/watch?v=3S-3J-FySzc
    • xeos
      • Apr 2014
      • 38
      • usa
      It depends a lot on the brand and how hard they are driven too. my real question is how common is it for a modern TV to be taken down by a bad cap? I know how to fix those and so I've eagerly taken dead TVs in the past and fixed them most of the time. But the last two that I picked up were LED TVs with no sign of bad caps and much less hope that I can fix them. Fluke, or the new lay of the land?
      • jjanssen7
        • Nov 2012
        • 252
        In my experience, capacitors still are sometimes (but not often) the problem as they are somewhat more vulnerable to heat and age stress issues than other components. However, I've gone from about 95% bad cap repairs to about 5% or less of what I repair being due to bad caps. I also don't repair "off brands" as they have little to no resale value where I live.
        There seems to have been an epidemic that included items manufactured up until about 2012-2013, an epidemic that has fallen off significantly from there. (see note below). That's also in the 10 year window as mentioned by a previous poster, so I do expect to see a few bad cap issues remain.
        Anything older than 2015 is hardly worth repairing for me. Too great of a risk of the development of other problems (BGA faults, cold solder joint failure, other component failure) after resale and low resale values for 5-6 year old tvs.
        LED failure is the new epidemic. I'd say over 60% of what I'm able to repair is due to LED failure. That's where I start looking these days.
        Note from Wikipedia: A 2003 article in The Independent claimed that the cause of the faulty capacitors was in fact due to a mis-copied formula. In 2001, a scientist working in the Rubycon Corporation in Japan stole a mis-copied formula for capacitors' electrolytes. He then took the faulty formula to the Luminous Town Electric company in China, where he had previously been employed. In the same year, the scientist's staff left China, stealing again the mis-copied formula and moving to Taiwan, where they would have created their own company, producing capacitors and propagating even more of this faulty formula of capacitor electrolytes.
        • nomoresonys
          • 12269
          • U.S.
          Like everyone says, the biggest problem with led lit tvs is they are set up to fail, because the leds are driven too hard, it must be on purpose by the makers so they can "sell more tvs"?? So that's mostly the problem with led lit tvs not the caps near as much.
          • xeos
            • Apr 2014
            • 38
            • usa
            Good to know, thanks. Funny, LEDs were supposed to last forever compared to CFLs.
            I'm trying to fix a Samsung LED at the moment - I've read elsewhere that bad LEDs can fry the power supply, so even if my power supply tests bad I shouldn't try fixing it until I can verify the LEDs?
            • jjanssen7
              • Nov 2012
              • 252
              I think this is from Badcaps.net:
              What is the legend behind the badcaps? Well, the rather dubious story behind this problem is that a scientist working for the Japanese company Rubycon left the company and began working for Luminous Town Electric in China. He developed a copy of the Rubycon P-50 water based electrolyte which is what they use in the Low-ESR caps that are present on all motherboards. Unfortunately his staff left and stole his electrolyte formula. They started producing tons of the electrolyte and supplied many Taiwanese capacitor manufacturers. Unfortunately the formula was incomplete and did not contain the additives that prevent electrolysis from occurring inside the capacitors and releasing hydrogen gas which bursts the capacitor at the vents at the top or at the bottom of the capacitor can.
              • jjanssen7
                • Nov 2012
                • 252
                Yes, especially with certain Samsung Tvs. I can think of a few 55" & 58" models right off the top.
                Better to post a new topic asking a question about your specific model at this point...
                • nomoresonys
                  • 12269
                  • U.S.
                  Sometimes it's not the tv twice a year it's just this:
                  https://blog.rittercommunications.co...nal-scrambling
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4456
                    • Italy - Milan
                    The LCD displays no more fails for bad caps, and this is the fact that i daily see... so it's obvious that caps improved in quality and the less heat helps.. by the way i can also think that those were the first stage of the so called programmed obsolescence, that method is become not useful due to large usage of people self repairing them, now the obsolescence methods are more sophisticated..
                    • nomoresonys
                      • 12269
                      • U.S.
                      "now the obsolescence methods are more sophisticated.." Care to elaborate, what other methods have you seen then?
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4456
                        • Italy - Milan
                        i don't interfere with you
                        • xeos
                          • Apr 2014
                          • 38
                          • usa
                          idk I see a lot of tvs thrown away. I don't think self repair is a big concern for them.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4456
                            • Italy - Milan
                            You see them now, now tv are much less repairable than 10 years ago, in my town even 5 years ago in the dumpser did found very few flat tv, so the bigger question is not the hobbyst but the repair centers, it's a job that has no future for low cost devices..
                            • xeos
                              • Apr 2014
                              • 38
                              • usa
                              Fair point. If they are unrepairable you'd see more tossed, eh? Meanwhile a pretty nice TV costs $200, which is wicked cheap. It's hard to get excited about repairing now that it's getting complex. I still hate the waste, though.
                                by momaka
                                03-15-2023, 10:17 PM
                              • wattage
                                by wattage
                                Hello Badcaps Community,
                                07-13-2025, 04:41 PM
                              • ant3202
                                HP 27es - LED monitor - Monitor Flashing On - Off
                                by ant3202
                                Hi Everyone
                                Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                https://www.badcaps.net/forum/troubl...lashing-on-off
                                The monitor is HP 27es LED Monitor
                                https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                The monitor will randomly blackout and display no signal and will recover again.
                                Sometimes need to power and off again to restore the display but...
                                03-20-2025, 07:30 PM
                              • Rick_1234
                                by Rick_1234
                                Good evening, gentlemen.
                                Things I tried
                                06-22-2024, 04:44 PM
                                Wise Wing F199 19'' LCD monitor - recapped
                                by momaka
                                Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                When I saw the Craigslist post, I wasn't...
                                08-24-2020, 10:58 AM
