TV Powers on, then Off - Emerson LF501EM5F
  • Shyguy707
    Newbie
    • Mar 2021
    • 4
    First off, yes I have seen the sticky for general troubleshooting as well as previous guides on this exact model, I actually followed one of them to get me to this point as my PSU was doing the chirping sound due to a malfunctioning C3214 capacitor.
    Now my T.V. actually turns on. As soon as I plug in the power cable into AC power (without touching power switch on T.V.), the screen will illuminate for a few seconds, then shut off. I press the power switch and the T.V. will do the same thing, refusing to stay on.
    I'm getting closer, but I need more help to get there, I would love to get this curbisde find up and running for my workshop!
    • 12274
    • U.S.
    Re: TV Powers on, then Off - Emerson LF501EM5F
    Test the voltages at the connector on the powerboard with EVERYTHING hooked up, it's the connector that the cable from powerboard to mainboard hooks into, most times there's a legend/map nearby that gives the expected voltages, you measure them with your mutimeter, set meter to 20 vdc then report them, put neg probe on chassis metal ground, pos probe on pin of connector, measure in standby take note, leave probes where they are then power on tv and again take note of voltages, report them here, example pin 1-ps-on-0 volts standby-power on-3.3 volts.
      • 12274
      • U.S.
      Can you post some focused straight on pictures of each board and one of the whole back, as to see how everything is connected?
        • 12274
        • U.S.
        Could be one or more additional bad caps.
          • 12274
          • U.S.
          Is your version DS1? can tell by looking on back cover, should be close to the model number.
          • Shyguy707
            Newbie
            • Mar 2021
            • 4
            See photos, according to serial number prefix, it may be a DS1.
            Here are the readings I've got, sorry if the layout is poor:
            Stand By Readings
            P1: 14.31V
            P2: 14.31V
            P3: 14.31V
            P4: 14.31V
            P5: 7.93V
            P6: 7.93V
            P7: 7.93V
            P8: 7.93V
            P9: 0mV
            P10: 0mV
            P11: 0mV
            P12: 0mV
            P13: 0mV
            P14: 3.315V
            P15: 0mV
            P16: 0mV
            P17: 3.315V
            P18: 0mV
            P19: 0mV
            P20: 0mV
            P21: 3.315V
            P22: 0mV
            P23: 0mV
            Power-On Readings
            P1: 22.68V
            P2: 22.68V
            P3: 22.68V
            P4: 22.68V
            P5: 13.02V
            P6: 13.02V
            P7: 13.02V
            P8: 13.02V
            P9: 0mV
            P10: 0mV
            P11: 0mV
            P12: 0mV
            P13: 0mV
            P14: 0mV
            P15: 3.314V
            P16: 3.05V
            P17: 3.3V
            P18: 3.0V
            P19: 3.10V
            P20: 3.2V
            P21: 3.314V
            P22: 424.8mV
            P23: 0mV
            • Shyguy707
              Newbie
              • Mar 2021
              • 4
              By the way, forgot to say thanks for the help, bud!
                • 12274
                • U.S.
                It's harder when the pins are not labeled, this board doesn't seem to have a label/legend, try heating with a hairdryer or cooling with freeze-spray or inverted can of air IC3006 on mainboard not powerboard, then plug tv in and see if it starts up or acts any differently.
                • malogro
                  Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                  by malogro
                  Hello all,
                  I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                  Intro:
                  This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                  Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                  04-14-2023, 04:44 PM
                • jose6326
                  Samsung s32d850t powers off
                  by jose6326
                  Powers on as normal shows an image then powers off after 10 seconds
                  I have to unplug it from the wall and replug to get it to turn back on but then shuts off
                  No blown caps
                  I searched for this model but nothing comes up...
                  11-29-2024, 11:21 PM
                • Rekoo1997
                  DELL Precision 3520 powers on automatically
                  by Rekoo1997
                  Laptop Model: DELL Precision 3520 Motherboard: CDP80 LA-E152P Rev 1.0 (A00)
                  Issue: The laptop powers on automatically after being shut down.
                  Actions Taken by Technician:
                  BIOS reflashed
                  Intel ME region cleared
                  Result: Issue still persists
                  Additional Observations:
                  Power button reads 3.3V (normal)
                  The problem occurs both when running on battery and when connected to AC adapter...
                  08-07-2025, 08:48 AM
                • simwalsh
                  Philips 47PFL4606 Powers on, works normal then powers off after a minute
                  by simwalsh
                  I am new to this forum and have searched for some answers with problems similar to mine.
                  Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
                  It sounds like a power supply issue?
                  I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
                  12-04-2023, 04:03 AM
                • csmith
                  Vizio D50u-D1 Powers up no picture
                  by csmith
                  I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                  Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                  supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                  issue. Set will power up with remote but not power off....
                  07-11-2025, 11:52 AM
