TV not powering on - with standby red –led flashing
  • nomoresonys
    • 12116
    • U.S.
    #61
    Re: TV not powering on - with standby red –led flashing
    Test c18-19 and 20 as described in post #55.
    • Willem01
      • Feb 2021
      • 45
      • South africa
      #62
      They all start from sbout from 2.9ohm and rise then until the meter shows a 1 or l
      • nomoresonys
        • 12116
        • U.S.
        #63
        And the other non-suspect caps do the same when tested? The rise should be even and steady.
        • nomoresonys
          • 12116
          • U.S.
          #64
          It can be tricky tracking down bad caps, it doesn't take much being out of specs to cause a problem, here's NorCal tracking some down:
          https://www.youtube.com/watch?v=3S-3J-FySzc
          • Willem01
            • Feb 2021
            • 45
            • South africa
            #65
            Found C16 to be doing nothing
            Edit... I set the meter to 2000k and then it show a steady increase,, so all the caps are good
            • nomoresonys
              • 12116
              • U.S.
              #66
              Well that's just a "dirty test", like I said a partial test you can try when you don't have the meters needed, to test them completely you need a meter or meters that can test capacitance and esr, the 10-20 dollar combo meters, there's a bunch on ebay, seem to be pretty accurate.
              • Willem01
                • Feb 2021
                • 45
                • South africa
                #67
                Ok so a recap on the existing issue:
                power cord plugged in for ever the standby led give a solid status - the tv switch on.
                Power cord unplugged for 40sec, plug it back in flashing led status - does not switch on only if I heatup C18, C19, C20 led status change to solid and it powers on.
                Have replaced all caps, done the 'dirty cap test' as per nomoresonys suggested, as I have not an ESR meter think the caps must be all good as they are new..
                Ai seems as IF I need to throw in the towel but dont want to
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  #68
                  On L1 it fluctuates 3.6 - 4.7 with the standby led flashing
                  When I unplug the CON3 plug for 10 sec plug it back the led stops flashing amd turn solid, then the volt on L1 is about 22v
                  D9 cathode voltage fluctuates from 21v - 60v that is without any pins jumped
                  D9 cathode is connected to L1 so the voltages should be the same.
                  I think that there is still aproblem with the standby circuit centered around U1 and Q4
                  Did you check D10 out of circuit.
                  R30 is 100 ohm and can you confirm that.
                  What value zener did you use to replace ZD3 which your schematic says is 18V
                  • Willem01
                    • Feb 2021
                    • 45
                    • South africa
                    #69
                    D9 to L1 - voltages are the same
                    R30-yes that is at 100ohm
                    Zener diode as in pic... Replaced it with a 18v one
                    D10 - help on this one, how do I measure {same as for any other diode} if so with the probes on the one way and then swapped the other way it does not matter what side I get one reading both ways 098 on multimeter
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      #70
                      is d10 removed from the circuit it should only measure in one direction
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        #71
                        In an earlier post this is what you gave
                        There is no reading for the 3.3v
                        C1 and C2 reads 315v for pinned and not pinned
                        Ohm readings for
                        ZD3... 00.4ohm
                        D10..25ohm
                        R26..00.5ohm
                        R28..510ohm(meter set to 2000ohm)
                        R29..18.7ohm
                        R30..25.1ohm
                        R31..00.7ohm
                        D10 is across 100 ohm resistor so should have read 100 ohms.
                        The only way to check is to lift D10 and put your meter in diode mode. You should have a reading one way eg 0.75 and no reading when you swap your meter leads over.
                        Then you can check that R30 does read 100 ohms
                        • Willem01
                          • Feb 2021
                          • 45
                          • South africa
                          #72
                          Agh sorry D10 is still in circuite,, will remove and give feedback again
                          • Willem01
                            • Feb 2021
                            • 45
                            • South africa
                            #73
                            D10 is lifted it gives me a reading only in one way on the diode test
                            When testing for resistance it gives 2.69ohms only in one direction
                            R30 gives me 98.6ohm
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              #74
                              2.69 ohms or 2.69 Kohms or 2.69 Mohms?
                              • Willem01
                                • Feb 2021
                                • 45
                                • South africa
                                #75
                                The multimeter is set like in the non illuminated display, sorry but I got another meter and is not confident in using it and feel silly
                                Added the wrong image before this is now correct
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  #76
                                  it's 2.69 Mohms, the range indicater is at the bottom MΩ
                                  • Willem01
                                    • Feb 2021
                                    • 45
                                    • South africa
                                    #77
                                    Do I have to replace it, if so can I use the one as per attatchment
                                    • nomoresonys
                                      • 12116
                                      • U.S.
                                      #78
                                      If it's still out of circuit, check it in diode mode.
                                      • Willem01
                                        • Feb 2021
                                        • 45
                                        • South africa
                                        #79
                                        It give a reading only in one direction
                                        • nomoresonys
                                          • 12116
                                          • U.S.
                                          #80
                                          That's what you want from a good diode.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • STKR123
                                            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                            by STKR123
                                            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                            I wonder if re-flashing the BIOS might be of any use here.
                                            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                            11-03-2024, 06:58 AM
                                          • Green Probe
                                            Recapping a Denon AVR X6400h SMPS
                                            by Green Probe
                                            (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
                                            Disclaimer: I'm an amateur hobbyist and will get things wrong.
                                            Always use caution when working around mains power and high voltage capacitors!
                                            Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
                                            SYMPTOMS:
                                            -No display...
                                            Today, 03:36 PM
                                            03-31-2024, 02:12 PM
                                          • SkishyIshy
                                            Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                            by SkishyIshy
                                            Hey All,
                                            I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                            I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                            I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                            03-17-2021, 11:44 AM
