TV not powering on - with standby red –led flashing
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: TV not powering on - with standby red –led flashing
    What dc voltage do you have at R17 (0 ohm resistor)
    Set your meter on with a range suitable to read the voltage between the two legs of C1 which is rated at 450V dc and let us know what it reads when P-ON is activated.
    • Willem01
      • Feb 2021
      • 45
      • South africa
      R17 - multimeter voltage= 0.03 en 0.0
      C1 - multimeter voltage = 317v - 320v
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        It looks like your PFC circuit is not working which is why the secondary voltages are not correct.
        With the mainboard disconnected from the power supply what dc voltage do you have between the two legs of C5 (or C6) on the power supply when you power up with the jumper connected to 3.3v to P-ON.
        Be carefull that the meter probes do not slip since this is on the high voltage side of the power supply.
        • Willem01
          • Feb 2021
          • 45
          • South africa
          Must I measure on the green lines as in the pic for C6
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            The capacitor does not need to be removed. You just measure the dc volts between the two points that the legs are soldered to the board so the answer is yes but put the capacitor back in the correct way around. The capacitor has a positive and negative leg Also don't forget to jumper P_On to 3.3V standby.
            • Willem01
              • Feb 2021
              • 45
              • South africa
              #26
              With the power disconnected and the P ON jumped,, it reads 12v
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                #27
                The power must be connected or you can't have 12V?
                • Willem01
                  • Feb 2021
                  • 45
                  • South africa
                  #28
                  Must I connect the power
                  Ok with the power connected it measure 12.3v,
                  I have heated up the board with a hairdryer and measured the pin outs on CON3 and they are all working as it should... Why is it working now
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    #29
                    With the mainboard disconnected from power supply and the 1K jumper resistor connected between P-ON and 3.3V, connect the power to the power supply board.
                    Measure the voltage across that capacitor and take care when making the measurement.
                    • Willem01
                      • Feb 2021
                      • 45
                      • South africa
                      #30
                      • Willem01
                        • Feb 2021
                        • 45
                        • South africa
                        #31
                        This is how it currently is, connected to power and all measurements on CON3 are in spec with the P-On bridged
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          #32
                          So connected like that at switch on the voltage across the capacitor measures 12.3V or does it go higher then drop and repeat?
                          The initial voltage to charge the capacitor at switch on comes from U1 which should charge the capacitor to 16V minimum to start the circuit oscillating that will then provide the secondary supplies.
                          • Willem01
                            • Feb 2021
                            • 45
                            • South africa
                            #33
                            Ok so I f#@ed up not been carefull and shorted these with the test probes
                            • Willem01
                              • Feb 2021
                              • 45
                              • South africa
                              #34
                              With the power connected it stays on 12.3v,when piwer is disconnected it starts draining down to 9v or as long as I keep the multimeter on it it goes lower
                              • Willem01
                                • Feb 2021
                                • 45
                                • South africa
                                #35
                                I put the board back in the tv and connected all the plugs and it switched on, to test it I unplugged the power from the wall socket for 1 minute, plugged it back in and have the led flashing led again and would not turn on, only until I bridge the P-On and 3.3v with power connected remove it and connect all connectors and power cord, then it switches on.
                                @dick_barton thanx for all your help so far until I get the part
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  #36
                                  Hello Willem01,
                                  I don't quite understand what you are trying to say here. What part are you waiting for?
                                  • Willem01
                                    • Feb 2021
                                    • 45
                                    • South africa
                                    #37
                                    When I done the test on C6 I accidentaly touched the Mosfet Q4... caused a short
                                    I was at the electronic shop they tested it and still works
                                    I soldered the heatsink and mosfet back into the board,, with the 3.3v and P-ON jumped and the power cord connected there is now a humming noise on the board and no readings on CON3, so I f&#@ed up��
                                    • dick_barton
                                      • Aug 2015
                                      • 6642
                                      • Wales
                                      #38
                                      Do you still have the 3.3V and if so what voltage do you have been the two legs of C1 or C2 with and without the jumper P-ON to 3.3V in place.
                                      I must admit that if the Gate and Drain pins on the mosfet were shorted out, then I cannot understand how it could have survived.
                                      With the set powered off set your meter to ohms and check ZD3, D10, R26, R28, R29, R30 and R31
                                      • Willem01
                                        • Feb 2021
                                        • 45
                                        • South africa
                                        #39
                                        There is no reading for the 3.3v
                                        C1 and C2 reads 315v for pinned and not pinned
                                        Ohm readings for
                                        ZD3... 00.4ohm
                                        D10..25ohm
                                        R26..00.5ohm
                                        R28..510ohm(meter set to 2000ohm)
                                        R29..18.7ohm
                                        R30..25.1ohm
                                        R31..00.7ohm
                                        • dick_barton
                                          • Aug 2015
                                          • 6642
                                          • Wales
                                          #40
                                          Either the gate/ source of the mosfet is short circuit or more likely the zener diode ZD3.
                                          You need to lift off ZD3 and make a note of which way around any markers are so it goes back in the exact same position. Then check its resistance when out of circuit.
                                          Can you post a photo of that area so I can see the components mentioned.
                                          R30 looks as though its a 100 ohm resistor so I think D10 is probably damaged as well
                                          I would double check the mosfet as shown in many Youtube videos for example
                                          https://www.youtube.com/watch?v=gloikp9t2dA
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • STKR123
                                            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                            by STKR123
                                            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                            I wonder if re-flashing the BIOS might be of any use here.
                                            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                            11-03-2024, 06:58 AM
                                          • Green Probe
                                            Recapping a Denon AVR X6400h SMPS
                                            by Green Probe
                                            (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
                                            Disclaimer: I'm an amateur hobbyist and will get things wrong.
                                            Always use caution when working around mains power and high voltage capacitors!
                                            Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
                                            SYMPTOMS:
                                            -No display...
                                            Today, 03:36 PM
                                            03-31-2024, 02:12 PM
                                          • SkishyIshy
                                            Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                            by SkishyIshy
                                            Hey All,
                                            I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                            I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                            I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                            03-17-2021, 11:44 AM
