TV not powering on - with standby red –led flashing
  • Willem01
    • Feb 2021
    • 45
    • South africa
    #41
    Re: TV not powering on - with standby red –led flashing
    Looks like you are right about the short circuite
    • Willem01
      • Feb 2021
      • 45
      • South africa
      #42
      Originally posted by dick_barton
      Either the gate/ source of the mosfet is short circuit or more likely the zener diode ZD3.
      You need to lift off ZD3 and make a note of which way around any markers are so it goes back in the exact same position. Then check its resistance when out of circuit.
      Can you post a photo of that area so I can see the components mentioned.
      R30 looks as though its a 100 ohm resistor so I think D10 is probably damaged as well
      I would double check the mosfet as shown in many Youtube videos for example
      https://www.youtube.com/watch?v=gloikp9t2dA
      I have removed it form the board, do I just measure it on the ohm setting of the multimeter?
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        #43
        You can set your multimeter to ohms. If it's short circuit then it will read 0 ohms or close to 0 ohms
        • Willem01
          • Feb 2021
          • 45
          • South africa
          #44
          OK so it is shorted,,,I cant get the same flatpin type, we only have the through hole kind with the same voltage spec. can I use that by trimming the wire so that it would fit on the board
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            #45
            If it fits without shorting out to the chassis when soldered in then it should be OK. What about the other components in the list. Have you checked them?
            • Willem01
              • Feb 2021
              • 45
              • South africa
              #46
              Oraait, the z-diode has been replaced and I have power to the board again, luckily that was the only part I needed to replace. All voltages on CON3 are in spec and the backlihgt led's are powering up.
              I still have one issue though, with the tv powered off and in standby mode after 5 minutes the led is not flashing, but when I push the power on button the led start flashing and doesnt come on.
              I did the following to test the standby power that is stored in the caps:
              I unplug the power cord from the tv, and still the the standby led is on I push the power-on button and the led goes out - this draining the standby power to power on the mainboard.
              To determine which cap is responsible for the standby power to be available. I plugged the power cord back into the tv with the standby led flashing, keeping an eye on it I heated each cap individually with a hair dryer and unplugging the power cord and pushing the power-on button again until I found which cap is the one - and it is C45.
              By reading the diagram C45 must be a 820uf10v cap, the cap that I have removed from the board was rated at 470uf10v.
              After all the caps was replaced the electronic shop gave me a 470uf16v cap for C45, would this be the issue with the cap that is out of spec that it still would not give power to wake up from standby mode.
              Only if I heat it up with the hair dryer on C45 it works 100% - how do I resolve this
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                #47
                Are there any components on the opposite side to C45 which may be heating up as you heat up C45. Is C30 in circuit? if so I would check that.
                Did you check the diode D15. Also check all the soder joints. Post a picture of the replacement capacitor. Ensure it's soldered in the correct way around.
                • Willem01
                  • Feb 2021
                  • 45
                  • South africa
                  #48
                  I have placed a piece of cardboard in between the caps to prevent the heat-flow to each of the other caps, I test it 3 times every time I heat up C43 the led goes solid. I can see C30 is not in circuit
                  C45 is that blue cap
                  Then on D10 I did measure it and there was a ohm reading cant remember now as the board is mounted again in its place.
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    #49
                    The view from the top of C45 doesn't give a lot of information. Can you post all that is wriiten on it.
                    Are you saying you're losing the 3.3V supply when the set is in standby ?
                    What voltage do you have on L1 link when in standby?
                    • nomoresonys
                      • 12116
                      • U.S.
                      #50
                      "470uf16v cap" Those specs are not a problem but you may just have a bad cap there.
                      • Willem01
                        • Feb 2021
                        • 45
                        • South africa
                        #51
                        C45 blue one, must I replaced it with another one
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          #52
                          No, It should be fine. Checking it was in correctly.
                          I think you are losing the voltage to U4 which is why the 3.3V is dropping. It would be interesting to see what voltage is on D9 cathode and whether it does drop in standby.
                          • Willem01
                            • Feb 2021
                            • 45
                            • South africa
                            #53
                            For the heck of me, where do you find those components,,been looking and looking but not getting it
                            OK found the buggers you are referring to...how do I go about to measure to answer your Q
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              #54
                              Here we are as per your photo
                              • nomoresonys
                                • 12116
                                • U.S.
                                #55
                                An easy way to partially test a cap in circuit is to set your meter to 20k ohms and put a meter lead on each leg of the cap and see if it goes up steadily or down steadily, can test one nearby to compare if they are acting the same. As always be careful not to touch capacitors leads with your hands as they can carry a DEADLY CHARGE, that one shouldn't as it's 16v but the big ones do.
                                • Willem01
                                  • Feb 2021
                                  • 45
                                  • South africa
                                  #56
                                  I tried to resimulate the heating of the blue cap,, its not tbat one.
                                  I isolated C18, C19, C20 heated them with the hair dryer and the standby led came to a solid on state and the tv powers up.
                                  Remember I replaced all the caps except C1 and C2
                                  Is there something in circuite I can check why when I heat them up it opens the 3.3v standby power
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    #57
                                    What is the answer to the above questions?
                                    • nomoresonys
                                      • 12116
                                      • U.S.
                                      #58
                                      Make sure C45 is not in backwards.
                                      • Willem01
                                        • Feb 2021
                                        • 45
                                        • South africa
                                        #59
                                        On L1 it fluctuates 3.6 - 4.7 with the standby led flashing
                                        When I unplug the CON3 plug for 10 sec plug it back the led stops flashing amd turn solid, then the volt on L1 is about 22v
                                        D9 cathode voltage fluctuates from 21v - 60v that is without any pins jumped
                                        • Willem01
                                          • Feb 2021
                                          • 45
                                          • South africa
                                          #60
                                          See post #51 image
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • STKR123
                                            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                            by STKR123
                                            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                            I wonder if re-flashing the BIOS might be of any use here.
                                            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                            11-03-2024, 06:58 AM
                                          • Green Probe
                                            Recapping a Denon AVR X6400h SMPS
                                            by Green Probe
                                            (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
                                            Disclaimer: I'm an amateur hobbyist and will get things wrong.
                                            Always use caution when working around mains power and high voltage capacitors!
                                            Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
                                            SYMPTOMS:
                                            -No display...
                                            Yesterday, 03:36 PM
                                            03-31-2024, 02:12 PM
                                          • SkishyIshy
                                            Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                            by SkishyIshy
                                            Hey All,
                                            I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                            I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                            I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                            03-17-2021, 11:44 AM
