Netflix app not working on Panasonic tv
  • GCM
    • Jun 2020
    • 11
    • Zambia
    Greetings to all,
    I have the Panasonic Th-75EX750M and Th-65EX750m and on both of them the Netflix app stopped working.I have tried to reset the app and restarted but nothing seems to work.
    Any with some IT knowledge on how I could enable the Netflix to come back to life?
  • GCM
    • Jun 2020
    • 11
    • Zambia
    Re: Netflix app not working on Panasonic tv
    Anyone to help me on the Netflix not working
    • Diah
      • Feb 2013
      • 6593
      the answer is clear.. 2 TV the same app didn't work,, so the problem at account.. or your IP became black list... or yours internet connection... or yours internet provider... all reason belong to internet gate way starting from router to until yours provider or account
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        I had this problem on a Panasonic plasma tv. I had to go into settings and do sort of a factory reset. Then everything was fine. It won't work if you do tbe First Time Setup screen.
        • nomoresonys
          • 12331
          • U.S.
          Do you have another tv you can try it with?
          • GCM
            • Jun 2020
            • 11
            • Zambia
            All the other apps on the TVs are working perfectly well apart from Netflix.
            Would anyone have solution to solving this problem?
            • anupkg1985
              • Sep 2020
              • 180
              What's the exact issue you are facing? App doesn't respond or doesn't play movies?
              • nomoresonys
                • 12331
                • U.S.
                Go to network settings of tv, change DNS setting to 8.8.8.8
                • GCM
                  • Jun 2020
                  • 11
                  • Zambia
                  Yes! It doesn't respond and hence not showing movies
                  • GCM
                    • Jun 2020
                    • 11
                    • Zambia
                    Oh okay,will try this as well and give feedback
                    • GCM
                      • Jun 2020
                      • 11
                      • Zambia
                      I have tried this method and nothing is working.
                      • GCM
                        • Jun 2020
                        • 11
                        • Zambia
                        The way you have explained,it looks certain that the problem could be
                        with the Netflix Acount or issues do with the Netflix provider.
                        I will check with them and revert back.
                        • anupkg1985
                          • Sep 2020
                          • 180
                          I don't think it's an issue with account or ip otherwise it would have displayed an error message accordingly. Try factory reset as it could be an issue with the latest update with that app.
                          • nomoresonys
                            • 12331
                            • U.S.
                            Is there an error message, does it say unable to connect to netflix?
                            • Diah
                              • Feb 2013
                              • 6593
                              just change the last letter or No at yours TV serial No via service menu. you will bypass any previous illegal activities or the first trail period of time .. so both TVs app Netflix will working again ... LOL
                              • GCM
                                • Jun 2020
                                • 11
                                • Zambia
                                I did factory reset the first time I noticed this problem and it never worked
                                • GCM
                                  • Jun 2020
                                  • 11
                                  • Zambia
                                  Will try it and thanks!
                                  • nomoresonys
                                    • 12331
                                    • U.S.
                                    Can't help you if you don't answer questions promptly, have now lost what little interest in this problem that I did have.
                                    • Ady2017
                                      Panasonic DMR-EZ48V DVD/VHS combo - DVD recorder part not working
                                      by Ady2017
                                      I have recently inherited a Panasonic DMR-EZ48V DVD/VHS combo after my dad died. I tried to record a DVD with it and it worked for about 5 mins before it suddenly stopped. Since then it just keeps making a noise like it is trying to read a disk but then gives a 'no read' error message. I have tried numerous DVD's and it is definitely the recorder that is the problem. I did find a youtube video showing that capacitors on the power board were a common problem on these and so I went ahead and replaced the capacitors but it is still doing the same thing. I now think that it could be the laser that...
                                      06-06-2025, 08:05 AM
                                    • Bazfletch3
                                      Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                      by Bazfletch3
                                      Hi all
                                      While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                      I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                      From there I envisaged that the backlighting wasn't working, however...
                                      01-08-2024, 10:18 PM
                                    • kd9
                                      Panasonic working hours bios location
                                      by kd9
                                      Hello, can someone tell me where the operating hours are located in the bios (string)? I have a client with a cf-20 who wants to reset them but I don't know where that information is found in the bios I we checked 2 versions of the bios but there are multiple large arrears that are changed . Thank you.
                                      04-03-2025, 09:47 PM
                                    • TyMercer
                                      Can I flash a working BIOS from one computer to another of the same make, model, etc?
                                      by TyMercer
                                      Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
                                      11-13-2025, 09:39 PM
                                    • BigPete
                                      Panasonic Heatpump Dryer Repair
                                      by BigPete
                                      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                      Unfortunately the whole machine has to come apart to fix it.
                                      I have...
                                      11-01-2025, 06:40 PM
