Netflix app not working on Panasonic tv
  • GCM
    • Jun 2020
    • 11
    • Zambia
    Greetings to all,
    I have the Panasonic Th-75EX750M and Th-65EX750m and on both of them the Netflix app stopped working.I have tried to reset the app and restarted but nothing seems to work.
    Any with some IT knowledge on how I could enable the Netflix to come back to life?
  • GCM
    • Jun 2020
    • 11
    • Zambia
    Re: Netflix app not working on Panasonic tv
    Anyone to help me on the Netflix not working
    • Diah
      • Feb 2013
      • 6439
      the answer is clear.. 2 TV the same app didn't work,, so the problem at account.. or your IP became black list... or yours internet connection... or yours internet provider... all reason belong to internet gate way starting from router to until yours provider or account
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        I had this problem on a Panasonic plasma tv. I had to go into settings and do sort of a factory reset. Then everything was fine. It won't work if you do tbe First Time Setup screen.
          • 12276
          • U.S.
          Do you have another tv you can try it with?
          • GCM
            • Jun 2020
            • 11
            • Zambia
            All the other apps on the TVs are working perfectly well apart from Netflix.
            Would anyone have solution to solving this problem?
            • anupkg1985
              • Sep 2020
              • 180
              What's the exact issue you are facing? App doesn't respond or doesn't play movies?
                • 12276
                • U.S.
                Go to network settings of tv, change DNS setting to 8.8.8.8
                • GCM
                  • Jun 2020
                  • 11
                  • Zambia
                  Yes! It doesn't respond and hence not showing movies
                  • GCM
                    • Jun 2020
                    • 11
                    • Zambia
                    Oh okay,will try this as well and give feedback
                    • GCM
                      • Jun 2020
                      • 11
                      • Zambia
                      I have tried this method and nothing is working.
                      • GCM
                        • Jun 2020
                        • 11
                        • Zambia
                        The way you have explained,it looks certain that the problem could be
                        with the Netflix Acount or issues do with the Netflix provider.
                        I will check with them and revert back.
                        • anupkg1985
                          • Sep 2020
                          • 180
                          I don't think it's an issue with account or ip otherwise it would have displayed an error message accordingly. Try factory reset as it could be an issue with the latest update with that app.
                            • 12276
                            • U.S.
                            Is there an error message, does it say unable to connect to netflix?
                            • Diah
                              • Feb 2013
                              • 6439
                              just change the last letter or No at yours TV serial No via service menu. you will bypass any previous illegal activities or the first trail period of time .. so both TVs app Netflix will working again ... LOL
                              • GCM
                                • Jun 2020
                                • 11
                                • Zambia
                                I did factory reset the first time I noticed this problem and it never worked
                                • GCM
                                  • Jun 2020
                                  • 11
                                  • Zambia
                                  Will try it and thanks!
                                    • 12276
                                    • U.S.
                                    Can't help you if you don't answer questions promptly, have now lost what little interest in this problem that I did have.
                                    • Ady2017
                                      Panasonic DMR-EZ48V DVD/VHS combo - DVD recorder part not working
                                      by Ady2017
                                      I have recently inherited a Panasonic DMR-EZ48V DVD/VHS combo after my dad died. I tried to record a DVD with it and it worked for about 5 mins before it suddenly stopped. Since then it just keeps making a noise like it is trying to read a disk but then gives a 'no read' error message. I have tried numerous DVD's and it is definitely the recorder that is the problem. I did find a youtube video showing that capacitors on the power board were a common problem on these and so I went ahead and replaced the capacitors but it is still doing the same thing. I now think that it could be the laser that...
                                      06-06-2025, 08:05 AM
                                    • Bazfletch3
                                      Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                      by Bazfletch3
                                      Hi all
                                      While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                      I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                      From there I envisaged that the backlighting wasn't working, however...
                                      01-08-2024, 10:18 PM
                                    • kd9
                                      Panasonic working hours bios location
                                      by kd9
                                      Hello, can someone tell me where the operating hours are located in the bios (string)? I have a client with a cf-20 who wants to reset them but I don't know where that information is found in the bios I we checked 2 versions of the bios but there are multiple large arrears that are changed . Thank you.
                                      04-03-2025, 09:47 PM
                                    • BadTelly
                                      HDMI ports not working - Panasonic model number TX-P50XT50B 50"
                                      by BadTelly
                                      Suddenly all HDMI ports stopped working on a Panasonic 50" TV. This is model number TX-P50XT50B and has worked fine for years.
                                      The TV turns on but no joy on either HDMI-1 or HDMI-2 and I've tested it using an input device and cable that works fine on another TV via HDMI.
                                      Thank you in advance for any help/ advice.
                                      Kind regards,
                                      Bad Telly
                                      11-26-2022, 11:26 AM
                                    • MMH3
                                      Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                                      by MMH3
                                      i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                                      Never ever i experienced problems with that.
                                      Now i have one 5050sff machine, where this jumper isnt working at all.
                                      I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                                      The history of the machine is that i used it in my office...
                                      03-23-2025, 09:28 PM
