TCL u55p6006 no backlight
  • wylcot
    • Dec 2020
    • 29
    • France
    So someone left me a TCL u55p6006 with no backlight.
    I can see the image is on with a lamp, and it actually flickers once when switching it off.
    I guess it's usual issue of dead leds, so I was wondering how I could check which ones are the faulty ones.
    Is there any good tutorial on how to do it? Which led tester should I buy if any?
    Thanks in advance.
  • neilc6
    • Nov 2015
    • 1550
    Re: TCL u55p6006 no backlight
    Replace all the strips with new and turn down the backlight level. All the LEDs have wear and the working ones will likely fail
    • wylcot
      • Dec 2020
      • 29
      • France
      Oh !
      All of them ?!
      Okay...
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • hollox123
        ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
        by hollox123
        Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
        1. Laptop keyboard doesn't work
        2. The backlight on the laptop keyboard doesn't work
        3. The x2 side LEDs (red) on the laptop don't work
        The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
        I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
        But I am strongly aiming that it is somehow a BIOS-related problem,...
        05-11-2025, 08:05 AM
      • signal.quest
        Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
        by signal.quest
        I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
        03-17-2024, 10:14 AM
      • DanPoka
        Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
        by DanPoka
        I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
        Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
        This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
        02-15-2025, 05:05 AM
      • Comp_Pro
        No Backlight Macbook A1990 820-01041
        by Comp_Pro
        Hello all,
        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
        Tests performed:
        There is no backlight even with a good screen.
        Backlight IC is receiving the correct support voltages.
        Fuse F8400 ok
        Current sense resistor R8400 ok
        Backlight IC is receiving 3.3V on enable pin.
        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
        Backlight IC receiving 5V from PP5V_G3S
        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
        05-06-2024, 10:23 PM
