TCL u55p6006 no backlight
  • wylcot
    • Dec 2020
    • 29
    • France
    So someone left me a TCL u55p6006 with no backlight.
    I can see the image is on with a lamp, and it actually flickers once when switching it off.
    I guess it's usual issue of dead leds, so I was wondering how I could check which ones are the faulty ones.
    Is there any good tutorial on how to do it? Which led tester should I buy if any?
    Thanks in advance.
  • neilc6
    • Nov 2015
    • 1550
    Re: TCL u55p6006 no backlight
    Replace all the strips with new and turn down the backlight level. All the LEDs have wear and the working ones will likely fail
    • wylcot
      • Dec 2020
      • 29
      • France
      Oh !
      All of them ?!
      Okay...
      • pni
        Backlight panel diffuser melt by backlight leds broken
        by pni
        Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
        10-12-2025, 12:08 AM
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • hollox123
        ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
        by hollox123
        Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
        1. Laptop keyboard doesn't work
        2. The backlight on the laptop keyboard doesn't work
        3. The x2 side LEDs (red) on the laptop don't work
        The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
        I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
        But I am strongly aiming that it is somehow a BIOS-related problem,...
        05-11-2025, 08:05 AM
      • signal.quest
        Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
        by signal.quest
        I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
        03-17-2024, 10:14 AM
      • DanPoka
        by DanPoka
        02-15-2025, 05:05 AM
