lg 43UF6430-UB Problems
  • oldtiredtech
    • Apr 2013
    • 5
    • usa
    Menu and screensaver is good, but picture has horizontal lines and digital anomalies
    https://www.badcaps.net/forum/attach...1&d=1611805561
  • handsworth
    • Oct 2015
    • 175
    Re: lg 43UF6430-UB Problems
    Main board is bad. BGA IC chip went south.
    • neilc6
      • Nov 2015
      • 1550
      I have used this repair service a few times.
      https://ebay.us/Zev9kG
      • diif
        • Feb 2014
        • 6978
        • England
        What is the repair they do, is it a new IC or do they just reflow/reball the original ?
        • neilc6
          • Nov 2015
          • 1550
          When I asked before, he indicated he replaced the IC. I've had a board returned that was working (if I did the half screen tcon test, I would have figured out it was a bad panel before sending it in). Also had a few unrepairable.
            LCD LED TV Service Menu Codes
            ALL LCD LED TV SERVICE MENU CODES
            Service Menu Code with Board Name
            China Universal Board / Jumper Board Service Menu Code
            Changhong Ruba Service Menu Code
            Ecostar LED TV Service Menu Code
            Orient LED TV Service Menu Code
            Haier LED TV Service Menu Code
            TCL LED TV Service Menu Code
            Samsung LED TV Service Menu Code
            LG LED TV Service Menu Code
            Videocon LED TV Service Menu Code
            Supra LED TV Service Menu Code
            Toshiba LED TV Service Menu Code
            Symphony LED TV Service Menu Code
            Veste/ LED TV Service Menu Code...
            10-31-2024, 03:58 AM
          • Robby-Gr
            TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
            by Robby-Gr
            I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
            However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
            The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
            Additional issues:...
            09-27-2025, 12:02 AM
          • oldtiredtech
            by oldtiredtech
            01-25-2021, 03:08 PM
          • Retro140
            Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
            by Retro140
            So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
            To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
            06-18-2023, 06:13 PM
          • jean luc ferre
            laptop hp g72 b52sf screen problems
            by jean luc ferre
            on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
            the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
            i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
            i don't understand the reasons of the white stripe at the bottom of the screen below the task...
            06-07-2025, 03:27 PM
