Sony OLED XBR65A8G no video, PSU problem?
again... there are no such words t-con “Enable” signal... there data feed p+ p-, stand alone test can be done on all T-CON and its own Slave Panels.. over all brands with out F"""K “Enable” from mainboards
so stop nonsense discussions.
if you want to learn how open threat and ask, don't hijack other threatsLast edited by Diah; 10-27-2024, 03:04 PM.Comment
Carefully clean the contacts on the bottom and top of these 4 cables, also replace the lvds cable...Comment
if you are so sure 100% then as yours ribbon photo there are damage with 2 wide lines from both side.. this will reduce the Ohm. so the mAm calibration will be effected-Comment
by the way i wrote to you before... did you put the Original T-con? if yes then change the ribbon at least the result will be more betterComment
by alro7779Hello, everyone!
A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,... -
by SpikemanHi, I'll tell you the story of this PC.
The PC was repaired because it had a shorted power supply. What happened was that the plastic covering the buffer battery positioned by the manufacturer on the capacitor melted, thus generating a short.
After the repair, the PC worked, I installed Windows 11 and I may have had some problems with the video drivers, but after a bit of tinkering I think I solved them.
However, the PC later presented the problem in the video shared very frequently.
The problem also occurs at startup, in the bios and when using it as a monitor thanks...-
02-27-2024, 10:17 AM -
by Gibon378PC Specs:
- CPU: Ryzen 5 1600
- GPU: GTX 1080 Palit JetStream
- MOBO: ASRock ab350 PRO4
- RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
- PSU: XFX 650W (don't remember what model)
- OS SSD: ADATA SP920
- OS: Windows 10 21H2
Problem description:
Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders... -
by zimeyhHi guys! I have a problem with macbook pro A1502. This display have a apple video, when launch desktop, this display is off. A connect thunderbolt a monitor, have video and laptop and monitor. Disconnect thunder video power off. Whats problem? 🤦🏻*♂️ thankss
by ChrissygizmoHello again everyone,
This is my latest mission, to try getting this Sony tv back to normal working order…
I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried... - Loading...
