THOMSON / TCL 43UC6406 jumping image
  • worlor
    • Oct 2020
    • 28
    • France
    Hello everyone
    I got a Thomson (TCL rebrand) 43UC6406 television with a jumping image problem.
    I have replaced the t-con board, but the problem continues ...
    I have make a video :https://youtu.be/v1Y_QfifP-E
    The motherboard nor his components are damaged
    I don't know what search next ? Can it be the LCD ? How can I check this ?
    Thanks for helping me save this !
  • Diah
    • Feb 2013
    • 6593
    Re: THOMSON / TCL 43UC6406 jumping image
    disconnect one ribbon cable at time ( the cable between t-con and panel) then turn on check if you have clear half screen..
    • worlor
      • Oct 2020
      • 28
      • France
      No I haven't clear half screen. See attached pictures.
      • Diah
        • Feb 2013
        • 6593
        bad panel.
        • worlor
          • Oct 2020
          • 28
          • France
          Originally posted by Diah
          bad panel.
          • Diah
            • Feb 2013
            • 6593
            Originally posted by worlor
            take out the speaker and the metal plate to have access to the panel edge boards... take look there if you are lucky you could find visible issue
            • worlor
              • Oct 2020
              • 28
              • France
              No visible issue ...
              • Diah
                • Feb 2013
                • 6593
                take out the both ribbon cable out and inspect them under loop if there any damage at the pins contact.. after inspection and they are fine put them back but the long blue area should be at T-CON side.. not as its now.
                also inspect the LVDS cable from the mainboards side.. dont forget to take the main boards out side the set and clean it very well from the dust it have from both side.
                • worlor
                  • Oct 2020
                  • 28
                  • France
                  I cleaned everything and the ribbons cable are OK.
                  When I connect only right side of the screen, I got a half-screen white and the other black, on the white side there is black line and the "jumping" effect is present on the right side. When I connect only the left side of the screen, just a half white screen. I have tried swaping the two ribbon cable -> same result.
                  No changes when I move gently the board when screen on.
                  Also, the t-con get very hot.
                  • Diah
                    • Feb 2013
                    • 6593
                    yours photos on post #3 when you disconnect one side ribbon are different from yours last photos after you inspect the cable !!!!!! ????
                    how it come?? are you sure the ribbon are fine???
                    • worlor
                      • Oct 2020
                      • 28
                      • France
                      On post #3 there was a boot logo when I boot up the TV with the 2 ribbon cable. Now the screen is completely black. I don't know why.
                      The boot up process work because the leds lights up then down
                      • Diah
                        • Feb 2013
                        • 6593
                        so the actual T-CON toasted !!!
                        • worlor
                          • Oct 2020
                          • 28
                          • France
                          I have tried with the other one and black screen too :/
                          • Diah
                            • Feb 2013
                            • 6593
                            you removed the main boards to cleaning the dust as i asked you... right ??? then you need to check if you did missed some things at MB
                            • sigmeyer
                              • Feb 2020
                              • 158
                              • Serbia
                              I saw a video online where some indian dude was messing with the buffer board on a LG tv with stutter problems ... He seemed to fix it by bypassing some IC.. Cant find the video of it right now but when i do i will post it so you can try.
                              • anupkg1985
                                • Sep 2020
                                • 180
                                I fixed same issue with VIZIO TV by putting small piece of tape on the cable connecting to LCD panel from t-con. I don't remember exactly but I placed tape on 3-4 pins and it worked.
                                  • 12331
                                  • U.S.
                                  +1, Yep, tape-cutoff method, might just work.
                                  • worlor
                                    • Oct 2020
                                    • 28
                                    • France
                                    Tried to tape pin 3-4 of the ribbon cable, green lines have appeared but the "wobbling" is still present :/
                                    • anupkg1985
                                      • Sep 2020
                                      • 180
                                      I'm not sure about the pin numbers and it could be different for TCL than Vizio. First you need to identify which side is the problem left or right bu disconnecting one cable cable at a time from t-con and check half image has that "wobbling" issue or not. Then you need to take brute force action to fixe the issue. As I said there is no specific number of pin that you need to block.
                                      • Diah
                                        • Feb 2013
                                        • 6593
                                        try the method on 1 or 2 or 3 or 4 pins on the side in photo
                                        • rimwall
                                          Sony KD-65x7500D - double image - Tcon or Panel?
                                          by rimwall
                                          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                          11-18-2025, 02:09 AM
                                        • jason123
                                          ASUS PG27V Rolling Image - TCON?
                                          by jason123
                                          Hi there,
                                          My son's gaming monitor started having rolling image (vertical roll - See Video) similar to vertical sync issue, or T-CON problems in TVs. Has anyone see this? is it fixable or a throw away?
                                          I haven't even opened it up yet. Does it have a T-CON? Help is appreciated.
                                          It does this even with the monitor not connected to a computer / graphics card....
                                          11-01-2025, 05:41 PM
                                        • jason123
                                          Hisense 65R6E3 double-image / horizontal strips - TCON?
                                          by jason123
                                          Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                                          07-19-2025, 08:07 AM
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
