LG 60PK750 no image.
  • 0yebob
    • Jan 2021
    Hi all. I've got a LG 60PK750, which recently stopped displaying images. The television still turns on (has sound and screen lightens) but no picture is displayed.
    I pulled off the back and checked voltages, and all seem in line with what's on the label.
    Next I figured I'd test the logic board, so I disconnected cable P31 and joined the r51 and r52 holes with a bit of wire, before turning on the television. The TV turned on and displayed test patterns, which I kept running for a while to ensure it could be sustained.
    Since it was able to display a series of images of various colors just fine when the only change I made was to the logic board (the bit of wire seemed the deciding factor, rather than the P31 unplug), that suggested to me that the logic board was the source of my issues, rather than a power or sus issue. However when I installed a replacement I had the same exact problem from the start, and when I performed the r51/r52 test on the new board it also produced test patterns.
    I see three possibilities here:
    1. I was shipped a faulty replacement logic board.
    2. I'm a moron and the problem is actually with the board I've been considering "just the a/v input board", not the logic board.
    3. The problem lies elsewhere.
    I don't see how 3 is possible, given the board-isolating nature of the testing. However people here are more experienced than I am, so I thought I'd post here before throwing money at another replacement board. My gut is leaning towards situation 2.
    If anyone has any thoughts or insights, I'd welcome them.
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Re: LG 60PK750 no image.
    I have the exact same symptoms on a Panasonic plasma. I have a thread a couple posts down from this one. Haven't got any replies yet so it mustn't be very obvious what the problem is. If I manage to figure the problem out I'll be sure to post it and explain how I found it so hopefully it can help you narrow your problem down.
    Do you have any pictures of the back of the TV so we can see how the boards are laid out and also pictures of the two boards in question?
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
    • diif
      • Feb 2014
      • 6978
      • England
      It reads like you're doing the test with the jumpers on the control board and this is testing the mainboard. They are known for having a bad BGA under the processor.
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        You definitely have a bad mainboard!
        • ohren
          by ohren
          09-08-2023, 05:24 PM
        • korben_dallas
          Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
          by korben_dallas
          Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
          I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
          I'm new to soldering but the only feasible way to fix this issue is to do something myself.
          MY QUESTION:
          I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
          02-14-2024, 12:23 AM
        • Stephen
          A2991 Logic Board issue, 20volts 0 amps help!
          by Stephen
          Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
          09-10-2025, 03:16 PM
        • Stephen
          A2991 logic board issue, 20volts 0 amps help!
          by Stephen
          09-10-2025, 03:15 PM
