Panasonic Viera tv P46st30 no standby light
  • waakye
    • Dec 2018
    • 340
    • Electronada
    Hi guys,
    I have this Panasonic plasma tv which exhibit a no standby led. I read through a few posts and even bought a new A board from eBay and the set still has no standby light. I am measuring standby voltage of 4.99vdc at P6 pin 6 on the P board. Any help will be appreciated.
    Photos attached.
    Thanks in advance
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Panasonic Viera tv P46st30 no standby light
    Press the power button for 5 seconds, release, and then press it again to see if there is any blink codes present.
    • waakye
      • Dec 2018
      • 340
      • Electronada
      Hi tvtimmy,
      Thanks for replying. I pressed the POWER button for 5 seconds and released and press's it again and there is no blink codes.
      Thanks in advance.
      • Diah
        • Feb 2013
        • 6573
        yours photo
        the mainboards its working and you have the Optical Audio OUT LED indicator lid ON ..!!! so you should have the 15V on power boards..
        • waakye
          • Dec 2018
          • 340
          • Electronada
          Thanks Diah.
          What do you guys think is the next course of action.
          Thanks again guys
          • waakye
            • Dec 2018
            • 340
            • Electronada
            This is the measurements on all pins on P6
            Pin 15 (15Vs) = .922vdc
            Pin 14 (GND)
            Pin 13 (15Vs) = .922vdc
            Pin 12 (GND)
            Pin 11 (F15V) = 15.73vdc
            Pin 10 (F15V) = 15.73vdc
            Pin 9 (GND)
            Pin 8 (GND)
            Pin 7 (F_STANDBY_ON) = 4.98vdc
            Pin 6 (STBY 5V) = 4.98Vdc
            Pin 5 (STBY 5V_ON) = 25.8mv
            Pin 4 (SOS4_PS) = 0.1mv
            Pin 3 (S0) = 09.2mv
            Pin 2 (S1) = 09.3mv
            Pin 1 ( Panel_Main_ON) = 3.8mv
            Thanks guys for your help again. Is it a power supply related issue?
            • waakye
              • Dec 2018
              • 340
              • Electronada
              Any help guys.
              • tvtimmy
                • Mar 2015
                • 1160
                • usa
                Check s20on the sc board for a short across the 2pins.
                • waakye
                  • Dec 2018
                  • 340
                  • Electronada
                  Hi tvtimmy, which 2 pins on SC20 should a check the short on?
                  • tvtimmy
                    • Mar 2015
                    • 1160
                    • usa
                    Sorry, I meant SN2. Check across the unplugged connector pins. A beep longer than 3 seconds means you have a short.
                    • waakye
                      • Dec 2018
                      • 340
                      • Electronada
                      I can't seem to locate the SN2. Is it on the scan board?
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        The power supply in this schematic could be similar to your. Page 49
                        • waakye
                          • Dec 2018
                          • 340
                          • Electronada
                          Thanks dick_barton. I will take a look at it. Is it a power supply related issue?
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            I really do not know. It's just looking at the schematic it shows that Pin 15 & PIn 13 of P6 are not at 15V. It could be that it is not being switched on.
                            Q500 is switched on and the 15V at the input is routed to Pin 10 & Pin 11 of P6.
                            The input to Q500 (at 15V) also goes to the input of Q502.
                            I would check the voltages on the pins of Q502
                            Edit
                            I wonder if Panel_Main_On should be at 5V to switch on Q502 (page36) This signal is sent by the mainboard to the power supply.(Page 33)
                            • waakye
                              • Dec 2018
                              • 340
                              • Electronada
                              Thanks dick_barton.
                              For some reason I cannot locate Q502 nor Q500 on the power supply board or just my eyes are no longer good.
                              I have attached the back side of my power supply board.
                              • tvtimmy
                                • Mar 2015
                                • 1160
                                • usa
                                The sn board is tbe one with all tbe brown ribbon connections. Here is the sn2.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  What voltage do you have for Vda (Connector P35) and Vsus (Connector P11 Pin1)
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    With the set off can you measure the resistance of P6 Pin15 to ground and also pin 13 to ground.
                                    • Diah
                                      • Feb 2013
                                      • 6573
                                      i am not good at plasma .. but his set working .. if he feed signal will hear sound .. standby light.. he mean indicator ? press the power on RC to turn off and you will have red LED indicator.. LOL... or my bad English a reason i didn't understood his question !!
                                      • waakye
                                        • Dec 2018
                                        • 340
                                        • Electronada
                                        tvtimmy, the measurements on SC20 on my board reads short(00.0ohm)
                                        @ dick_barton, when the set is off, pin 15 to ground measures 5.05kohms. pin 13 to ground also measures 5.05kohm
                                        When AC is plug in, P11 pin 1 measures 0.922vdc
                                        P35 pin 1 vdata 0.9mvdc
                                        @ Diah, what exactly do you want me to try.
                                        Thanks guys for all your help
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • MUNASHE
                                          Panasonic TH-32A315M, standby red light, but won't power on
                                          by MUNASHE
                                          Hi everyone
                                          I have a Panasonic TH-32A315M, that won't power on but standby red light is present
                                          Pliz help
                                          10-13-2022, 07:11 AM
                                        • brithepi2k
                                          Sony KD-65XE8596 no standby light
                                          by brithepi2k
                                          I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                          cheers...
                                          09-06-2025, 02:22 PM
                                        • AleMonti
                                          LG 55EG910V - no power and no standby light
                                          by AleMonti
                                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                          After checking the basics I did the following:
                                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                          11-04-2024, 05:02 PM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
