sony 43w755c rebooting
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    any help please, this tv keep rebooting . i have tried hard reset no solution
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4460
    • Italy - Milan
    Re: sony 43w755c rebooting
    Software issue much probably, needs reprogramming or file fixing, usually only way is mainboard replacing. Is it a smart tv?
    • zen
      • 511
      If your lucky enough for the set not to have the latest operating system firmware installed , an upgrade should restore functions .
      If you cannot recover it , there's a company in the United Kingdom called Micro tech , that offer a repair service .
      They may even advertise the service on EBAY.UK
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4460
        • Italy - Milan
        He is in Nigeria..
        • odie34
          Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
          by odie34
          I am a hobbyist (not a professional) so please be gentle...
          I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
          I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
          02-18-2024, 09:11 AM
        • Dan20701
          Dahua XVR Hard Reset, Locked 8 Channel CCTV NVR
          by Dan20701
          Hello all just wondering if anyone knows how to do a hard reset on this model, XVR58C-21D-8CH-V1.1 ?
          There are videos on youtube for every other model but this one, I do not have the switch on the board or reset jumpers.
          https://www.youtube.com/watch?v=Ao7EwIMDx_c
          I do have 2 little pads right next to the firmware chip, I have shorted these and powered the system on and waited a wile
          with no luck. I will add picture of these 2 pads.
          I do have the bin file from the firmware if its any good to anyone maybe able to edit out the pass I am not sure.
          02-28-2025, 09:13 AM
        • Carlos#2003%
          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
          by Carlos#2003%
          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
          02-15-2024, 07:52 PM
        • dkneyle
          Sony KDL-46HX850 Can't upgrade/update firmware
          by dkneyle
          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
          09-25-2024, 10:44 PM
          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-06-2024, 05:27 AM
