any help please, this tv keep rebooting . i have tried hard reset no solution
sony 43w755c rebooting
Re: sony 43w755c rebooting
If your lucky enough for the set not to have the latest operating system firmware installed , an upgrade should restore functions .
If you cannot recover it , there's a company in the United Kingdom called Micro tech , that offer a repair service .
They may even advertise the service on EBAY.UKComment
by odie34I am a hobbyist (not a professional) so please be gentle...
I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,... -
by Dan20701Hello all just wondering if anyone knows how to do a hard reset on this model, XVR58C-21D-8CH-V1.1 ?
There are videos on youtube for every other model but this one, I do not have the switch on the board or reset jumpers.
https://www.youtube.com/watch?v=Ao7EwIMDx_c
I do have 2 little pads right next to the firmware chip, I have shorted these and powered the system on and waited a wile
with no luck. I will add picture of these 2 pads.
I do have the bin file from the firmware if its any good to anyone maybe able to edit out the pass I am not sure.
Hi friends.
I have a Plaud Note that's asking me to unlink the SSO account.
Is there a solution to unlink this device?-
10-27-2025, 09:40 AM -
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
Hey there people
While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
This is what I tried, but not in any order.
Google
YouTube
BIOS
Command Prompt (administrator privileges)
On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...-
10-25-2025, 02:22 AM -
- Loading...
