LG 42LW4500 no picture no backlight but near all lines good
  • disorder
    • Sep 2015
    • 156
    • france
    hello, i have the same issue as this thread :
    https://www.badcaps.net/forum/showth...8668&styleid=8
    it's a 42LW4500 LG tv, previously it had the classical L407 classical issue : desoldering due to bad resin that gave me no 24V. work great for one month
    yesterday : sudenly, green light then screen shut down. white led ok
    open it and test : first put a resistor between 3,5 and PWR-ON, another one between 3,5 and inv_on : tv start, backlight ok and stable.
    but when the connector between motherboard and PSU is connected : i have 3,5V 12V 24V but NO INV_on, a_dim and p_dim.
    if i test ic1002 at inv_ctl : got 3.5V, r421 is good and Q405 no short.
    so i think my issue is due to P_dim (power dimming so)
    all pins joints were resoldered
    during all this tests, once the tv works for some seconds then shut down.
    thank you
    put here service manual .
  • nomoresonys
    • 12274
    • U.S.
    Re: LG 42LW4500 no picture no backlight but near all lines good
    Makes me think the same thing as the thread you refer to...that the mainboard is not sending the inverter on signal to the powerboard, I would try a replacement mainboard.
    • zen
      • 511
      I do recall working on one of these sets some time ago .
      The back light themselves can be very intermittent .
      In fact , on the one i had , set would run for 2 - 3 day without problem , before back lights cut out .
      • disorder
        • Sep 2015
        • 156
        • france
        hello , some news : problem seems to be solved
        after analysed a-dim p-dim and inv_on, many filters missing compared to schematics.
        so it was easier to find the culprit
        removed Q405 by another NPN transistor and since the tv works normaly
        (i took a npn with same values except cutoff at 0,1A )
        hope this will help someone else later :-)
        • zen
          • 511
          Great result , & thanks for the information .
          • disorder
            • Sep 2015
            • 156
            • france
            failure !!!
            the tv worked many time in my garage, just plug in in the house. worked for 20 minutes and then shut off and does the same weird issue.
            before shut off , screen goes like snow image as CRT screen
            maybe cold joints ? will look,
            • disorder
              • Sep 2015
              • 156
              • france
              finally got it.
              i baked it in oven and now it works great , maybe for some days or years.
              i have tried it for more than 15 hours wthout any problem.
              some bad solder joint so.
              Issue solved :-)) !
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • noisykid
                Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                by noisykid
                5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                12-30-2024, 07:15 PM
              • adamp91gvm
                hisense 55e76gqtuk seems to be downloading picture from top to bottom with lines
                by adamp91gvm
                as above shows coloured lines then slowly goes down and repairs the picture on start up if been on for a while then turned off its fine anyone had this...
                09-10-2025, 12:13 PM
              • hendue
                BenQ 2765HT vertical lines, no picture
                by hendue
                I was trying to fix the monitor, which was giving me the following pictures:
                It was somehow reactive, such that if I pressed the buttons, the lines changed in positions or if i moved e.g. a task window, it would somehow change the patter, too.
                I swapped out the mainboard without any luck. So I thought that it has to be an issue with the panel itself and was trying to assess whats wrong on the control board of the panel.
                Somehow, I managed to short the LVDS protection with a MOSFETS cooler on the PCB.
                I turned around...
                09-09-2025, 08:27 AM
              • srs
                Insignia NS-50DR620NA18 w/ large vertical lines & no picture
                by srs
                I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
                A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
                I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
                04-22-2023, 02:40 PM
