Samsung ue40j5200aw - Replacing chip on the T-con board.
  • gergely
    • Oct 2017
    • 25
    • Spain
    Hey everyone!
    I've got this TV from friend. My guess is t-con board is faulty.
    If i connect/disconnect the flat cable on tcon board this is the image i get.
    https://imgur.com/tv5Z1Ju
    then the picture will go away.
    I've measured a few things on the board. I didnt find any short. There are voltages but i dont know if they are correct.
    There is a main chip CM2801C which i think is faulty.
    There is an eeprom i could programme it whit this:
    https://repairalltv.com/t-con-v400hj...00hj6-pe1-12v/
    but my board is a rev C7.
    Any thoughts?
  • zens electronics
    • Jan 2021
    • 31
    • uk
    Re: Samsung ue40j5200aw - Replacing chip on the T-con board.
    Possibly , but more likely to be a display issue .
    • gergely
      • Oct 2017
      • 25
      • Spain
      You mean the LCD panel itself or those Ics on flex cable that attached to the panel?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4459
        • Italy - Milan
        Don't waste time and money, it's 100% display panel issue at gate.drivers, them are embedded in the glass so no handling or access is possible, sell all the boards..
        • neilc6
          • Nov 2015
          • 1550
          Connect only one side at a time between the tcon and panel. If one side is good, so is your tcon.
          • gergely
            • Oct 2017
            • 25
            • Spain
            hey! i dont have much hope. Me too was suspecting that the lcd panel. i did order a chip for 3 buck and i will see. Thanks for your comment
            • gergely
              • Oct 2017
              • 25
              • Spain
              hi! if i disconnect one side of the t-con, the right side of the lcd panel goes white.
              • advant
                by advant
                02-03-2020, 12:25 AM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • ohren
                Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                by ohren
                I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                The models launched in 2018 and 2019 respectively....
                09-08-2023, 05:24 PM
              • C152Heavy
                Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                by C152Heavy
                Summary for TL-DR readers:
                • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                • Have obtained Samsung schematic & service documents - Can upload if helpful.
                • Have read ALL applicable threads
                • C1818 and CP820 replaced as low hanging fruit
                • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                • VCC pin (18) of PFC...
                01-11-2023, 02:53 PM
              • MacGyver's paperclip
                what to check before replacing hybrid MOSFET/controller IC on SAMSUNG TV power board
                by MacGyver's paperclip
                TLDNR; Have an old SAMSUNG TV with blown hybrid MOSFET/controller IC on power board to be replaced; replaced blown main capacitor on same power board several years ago successfully, and TV has been working fine since until this IC popped all of a sudden. Want to know what if anything to check on board to make sure before replacing and testing with new IC. Have 2 new matching ICs, DIP socket to make removal/replacement easier, a whole other known-good power board with which to compare, if necessary.
                07-01-2023, 12:12 PM
