LG 49UF6490 screen issue
  • handsworth
    • Oct 2015
    • 175
    Waited for months to find this used main board cheap, It finally arrived today and after installed, everything works fine except that the screen is slightly darker on the right side. All leds are lit but the screen is about a half shade darker. I am thinking the connections between the main board, lvds, tcon or tabs that connect to the bottom of the screen. If anyone has come across this problem also, please advise. Thanks
  • handsworth
    • Oct 2015
    • 175
    Re: LG 49UF6490 screen issue
    Here are pics of what I got. Its the right side that's a shade darker. Switched tabs, lvds and cleaned connectors. Even did a _IN STOP. Difference is quite small but I can tell. Picture looks great from about 5ft. Any advise on what is causing this?
    • Diah
      • Feb 2013
      • 6600
      make firmware update or downgrade to let the T-CON firmware match the Main firmware
      • handsworth
        • Oct 2015
        • 175
        Updated software but no change. New Tcon solved the problem. Something on the old one must have been bad.
        • mazmaz
          • Jan 2021
          • 3
          • Iran
          Hi
          It seems that , may your TV's back-light settings make this.
          please set off local dimming on back-light settings.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            There was a post on here recently that had I believe to be an identical problem where they said replaciing the mainboard cured the problem.
            • vinceroger69
              • Mar 2012
              • 6714
              Originally posted by dick_barton
              There was a post on here recently that had I believe to be an identical problem where they said replacing the mainboard cured the problem.
              In post 3 i think he has now repaired the tv by fitting another t con but yes im sure i have read that fitting a replacement mainboard fixed another persons tv.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Mssed that. Thanks vinceroger69.
                • wizard13
                  Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                  by wizard13
                  I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                  I have checked the forum and the available documentation but could not find a solution specific to my issue.
                  • Brand & Model: Dynabook Satellite Pro C50D-B-100
                  • Part Number (P/N): PYU13E-00C00PFR
                  • Serial Number (S/N): 22028896H
                  • System Configuration (SC): A1PYU13E1127
                  • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                  • Power Input: DC 19V –
                  02-28-2025, 02:43 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • cloudy
                  HELP - Contrast/brightness issue with subtitles on screen
                  by cloudy
                  Hi everybody
                  Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
                  Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
                  Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
                  It occours both on ubuntu and windows...
                  01-01-2023, 05:12 PM
                • Rozp
                  70LE660U dark cloud or black screen with sound.
                  by Rozp
                  Hello Everyone,
                  This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                  I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                  08-29-2023, 05:25 PM
                • ScHAmPi
                  Samsung UE48JU7000 screen issue after backlight replacement
                  by ScHAmPi
                  Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
                  I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
                  07-15-2024, 05:41 AM
