TCL 75S425 Colored Lines - Panel Issue?
  • OcifferAction
    • Dec 2020
    I have a 75" TCL 75S425 model TV that randomly has colored vertical lines running down it. I replaced the T-Con board, but the issue still persists. I can navigate the menus and hear audio from selections, but I can't make out what any of the menus are. The lines change with the menu change. I know I haven't cracked or dropped the TV. It's been on the wall for a year and I haven't touched it. I'm not sure where to look next for a solution.
    https://imgur.com/WeE8nms
  • neilc6
    • Nov 2015
    • 1550
    Re: TCL 75S425 Colored Lines - Panel Issue?
    Bad panel. Not repairable.
    • Diah
      • Feb 2013
      • 6438
      wait.. at yours picture there are no any kind of real color lines.. just one color shadow. can you confirm ?
      • budwich
        • Jul 2015
        • 3097
        Based on the type of "display" in the top right corner of the set, you might have issues with the edge boards along the bottom of the tv... possibly a component part (smd capacitor).... it might be fixable with some careful soldering if you can locate it. You will need to access the area and do some electrical checks therein.
        Of course, there are other checks of voltages as identified / labelled on some of the cards that will help with any diagnosis.
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • NWArkGuy
          Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
          by NWArkGuy
          Well, I will be the first to admit that I screwed up...
          In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
          I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
          I have 2 that I have found and have in my possession. ...
          10-12-2023, 10:13 PM
        • learnmore
          Samsung UE70TU7020K Which lines to tape on a bad panel
          by learnmore
          Hello Community,
          I'm working on a Samsung UE70TU7020K.
          It looks like a bad panel. There is only 1 FPC cable from the Tcon (built into mainboard) to the panel.
          I'm using a piece of tap a few mils (covers about 8-10 pins), at different locations and have had varying results but nothing that is remotely watchable (multiple lines across all the screen, half screen and total black out on screen). The buffer board is divided into 3 boards. I've disconnected the end board one at a time but each time the screen was totally black. I presume it's because the potential...
          03-15-2024, 03:01 PM
        • Kikerumbo
          Mi Curved Gaming Monitor 34" - Horizontal lines
          by Kikerumbo
          Thanks in advance for any help you can provide.
          I have a Mi Curved Gaming Monitor 34". A few weeks ago it started to show (or not showing) horizontal lines. Of course, it's outside of the warranty period.
          After some hours of reading and watching videos I disassembled the monitor and checked the ribbons that go from the TCON board to the panel PCB. If I disconnect the ribbon for the right side of the panel, the other half shows a perfect image. I ordered a "new" TCON, installed it and the issue persists so that tells me it must...
          03-14-2024, 02:48 PM
        • DrvLikHell
          Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
          by DrvLikHell
          Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
          The...
          02-05-2025, 01:44 AM
