Philips 32pfk6509/12 turn on by yourself, cannot be turned off
  • palimre22
    • Apr 2019
    • 6
    • Hungary
    Hi everyone
    i would need a little help with the tv mentioned in the title.
    When switched on, it switches on automatically and cannot be switched off with the buttons on the device or remotely. In addition, it does not enter the menu.
    It's like being in hotel mode or being in it.
    is there any solution
    There is so much left that I can adjust the volume, I can make sound and input choices on my TV. and if i do select i hdmi 1 pl and i give it a signal the tv works flawlessly.
    responds to number buttons on the remote control, to select the sound mode and picture mode, service menube I can enter, I can change anything
    I have already checked the feeds and auxiliary feeds, I found no abnormality.
    sassi: tpm14.2e
    Hi Imre
  • Diah
    • Feb 2013
    • 6590
    Re: Philips 32pfk6509/12 turn on by yourself, cannot be turned off
    you can try to make hard reset via SAM service menu.. and choice "Initialize NVM " this will erease all tv setting.
    also you have option at FACTORY MODE service menu too to reset another child lock if it set on. choice "RESET_PBS_PWD"
    Inter SAM : press on RC “062596” ollowed by the “INFO”
    inter FACTORY MODE : with RC from the “Menu/Home screen” press “1999”, directly followed by the “Back” button
    • pajdek
      Lenovo Y700-17ISK turn on and off
      by pajdek
      Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
      09-20-2023, 02:49 AM
    • ovrax
      Philips 55PUS6804/12 turn on & off (probably backlight issue)
      by ovrax
      First of all, please excuse me as I'm quite new to this field.
      I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
      I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
      The Ambilight works perfectly and stays on.
      No sounds.
      Thanks in advance.
      08-25-2024, 04:33 AM
    • RdeveLabs
      MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
      by RdeveLabs
      To all the members here...
      Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
      So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
      05-05-2025, 04:59 AM
    • reessi
      Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
      by reessi
      Hello:
      I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
      I started on the ACER:
      Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
      All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
      I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
      10-29-2024, 11:31 AM
    • robante15
      Acer Aspire 4520 won't turn on after reboot
      by robante15
      Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
      It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
      The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
      If I remove the...
      04-06-2024, 06:50 PM
