Tcl 55s401taaa
  • larry708
    • Jan 2017
    • 15
    • us
    Tcl 55s401taaa
    so i see im having the same issue with this tv.. got sound got backlights but no screen i tryed on both sides of the cables going to the drivers no picture just the screen light up like the rest.. it worked fine just turned it off and it wont get a screen now. any one figgure this out.. how about a service manual or troubleshoot manual on this
  • neilc6
    • Nov 2015
    • 1550
    Re: Tcl 55s401taaa
    If you have 12V on both sides of the fuse to the tcon, then the tcon is suspect and time to order a new one.
      Re: Tcl 55s401taaa
      Show us good clear pictures of the backside of the TV showing all the boards so we can see what we are dealing with.
      • larry708
        • Jan 2017
        • 15
        • us
        Re: Tcl 55s401taaa
        suprised no one solved the issue on all these threads..
        • Plurxtc1
          • Oct 2014
          • 136
          Re: Tcl 55s401taaa
          @larry708 I had the same issue where I did not get a picture on either side after unplugging the ribbons from the T-Con to the panel. Replacing the T-Con fixed it. But it wasn't guaranteed because there was a few times on other sets did not fixed it. But you won't know without replacing the T-Con.
          • larry708
            • Jan 2017
            • 15
            • us
            Re: Tcl 55s401taaa
            im not having that luck
            • Plurxtc1
              • Oct 2014
              • 136
              Re: Tcl 55s401taaa
              you won't know without a new T-Con board, they're cheap
              • reformatt
                by reformatt
                07-31-2025, 08:37 PM
              • smic717394
                by smic717394
                07-25-2024, 10:16 AM
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • spice_disc
                Vizio TV M50-C1 reboot cycle and static on screen
                by spice_disc
                I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                09-08-2024, 02:37 PM
              • ipatch
                ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                by ipatch
                i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                08-24-2024, 02:36 PM
