Trust 40 no backlight
  • elpiko
    • May 2020
    • 25
    • Seychelles
    I got a trust 40 inch tv when power no backlight not turning on.but I can see logo if I use a flash light on screen. So I when to check the led strips one by one and all light up fine. Now on my main board just before the led ligh connector the m7 diode is shorting. but when I remove the diode from circuit no short.im suspecting the led driver ic OB3350 any idea?
  • yokoono
    • Apr 2010
    • 505
    Re: Trust 40 no backlight
    Also check the mosfet transistor that is controlled by the LED driver
    • unimatrix93
      TV backlight zener diode
      by unimatrix93
      Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
      So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
      Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
      The led strips has 9 6V leds.
      02-10-2025, 12:13 PM
    • triplefour
      by triplefour
      09-13-2023, 10:43 PM
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
    • cheebster
      iPad Pro 12.9 5th Gen Backlight Issue
      by cheebster
      Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
      Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
      Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
      The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
      Anyone...
      05-20-2025, 09:17 AM
    • canadaboy25
      LG Flatron 24EN33TA No Backlight When Cold
      by canadaboy25
      I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
      I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
      03-07-2023, 12:23 AM
