Inverter 316827000001-R0A transformers
  • Tips
    • Feb 2014
    • 15
    I have a failed inverter board, 316827000001-R0A from an Acer Aspire Z5700 AIO PC. (I know I am asking this question under TV's and video sources as I believe it is more relevant here than under PC's and I hope that is not an issue)
    The transformers have failed and I am struggling to identify them or find a suitable replacement for them. The only code printed on them is 273001050372 10252. (Please see attached pictures)
    Any advise or suitable compatible replacements would be most welcome, and thank you in advance.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Inverter 316827000001-R0A transformers
    If you can't find a replacement then maybe something like this could be substituted.
    https://tinyurl.com/y643vuew
    Or contact these people to see if they can help
    http://www.lcdparts.net/Transformer3D.aspx
    • Tips
      • Feb 2014
      • 15
      Thank you for your feedback, will look in to both options and hopefully find something that will do the job
      • ahmedtou
        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
        by ahmedtou
        help me please
        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
        I will share all the details with you, including the disc information.
        Code:
        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
        Current Profile: BD-R
        Disc Information:
        Status: Empty
        State of Last Session: Empty
        Erasable: No
        Free Sectors: 12,219,392
        Free Space: 25,025,314,816 bytes
        Free Time: 2715:27:17 (MM:SS:FF)
        Next
        08-27-2025, 08:49 AM
      • eccerr0r
        inverter H tree driver imbalance in an AC inverter
        by eccerr0r
        My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
        11-16-2025, 12:34 PM
      • x_orange90_x
        by x_orange90_x
        01-29-2025, 09:24 PM
      • keldeo
        How many of you have seen failed Panasonics!?
        by keldeo
        In my experience, I've seen failed Taiwan/Chinese caps, obviously as I'm sure all of us had. I've also seen the defective Nichicon and Chemi Con series. Even seen failed Rubycons (MBZ I think?) if they are exposed to a lot of stress and heat. I've never seen failed Panasonics until now! Not just one, but 3! Also in seemingly random locations on the motherboard. Next to the RAM and CPU, but not t part of the VRM. It felt like I spotted a Unicorn, so I had to make this post. Motherboard is a IPIBL-LA. OEM from HP.
        Unfortunately, I do not know the history behind this PC, it also had...
        Today, 02:36 AM
      • Gentian
        APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
        by Gentian
        I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
        It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
        03-06-2023, 07:07 AM
