fukuda FLED 4801dc
+ More Options
Posts
  • as1jc
    • Nov 2020
    • 16
    • philippines
    fukuda FLED 4801dc
    this thing is only 3 years old and its dead. given to me by an acquaintance. as the price was right and some study on fixing modern tv's online i quickly deduced that backlites were out and as there was no power at the sockets it must be the combination power supply,mother board. the flashlite test proved that the display worked. the board is a tp.vst59s.pc815. soooo i got on a asian buy and sell site LAZADA and found two boards for 2200 pesos or about 40 bucks. i tried them both but both produced a solarized display but had sound and wouldnt work with the fukuda remote but do with my lg remotes. ive since learned the the boards must be programmed. i dont have a clue how to do that. i would consider it a success if i could get the solarization fixed and just use an lg remote or a universal. not sure i can accept that the tcon board failed at the same time, but it would seem that its a likely scenario. what do you folks think? ive also read that the board has to be told what size the screen is (48'') i figured out how to get into the service menu but i cant seem to find a any adjustment, and to be truthful there seems to be HUNDREDS of parameter's that can be adjusted and im rather lost. im not against fixing this correctly and would prefer it but i'd like a little guidance a NEW tcon, 14y-vnb5.s120p2c4lv0.2 is 40 bucks id rather not spend on a used 400$ as new set. anybody got any ideas?
  • ramondo
    Confused Member
    • Jun 2015
    • 39
    Re: fukuda FLED 4801dc
    can you get to the service menu? sometimes a setting there will cause solarization.
    Thanks to all for being__WAR_KITTENS____!
    • as1jc
      • Nov 2020
      • 16
      • philippines
      yeah i did get into the service menu. from what i could deduce online (my first tv repair, i do tube radios mostly) its the lvds map it has a choice of a number 1-15 ,i think.what i did was put on a movie then got into that menu. while the picture was on i chose each number giving it some time to readjust. it did change things but would not cure solarization
        LCD LED TV Service Menu Codes
        TCL LED TV Service Menu Code
        LG LED TV Service Menu Code
        10-31-2024, 03:58 AM
      • Retro140
        Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
        by Retro140
        So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
        To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
        06-18-2023, 06:13 PM
      • Ierwin
        Philips 58PUS7805 Menu working but no/weird picture from video sources
        by Ierwin
        I got a 58pus7805 that shows some weird behavior.
        The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
        However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
        I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
        I managed to install the latest official firmware by holding the control button while plugging...
        03-10-2024, 12:50 PM
      • vf fa
        EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
        by vf fa
        Hi, so i guess Iยดll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
        I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
        So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
        01-31-2024, 01:40 PM
      • tusiime
        How to access Vizio m652i-b2 service menu
        by tusiime
        The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
        So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
        Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
        09-15-2023, 09:57 AM
