Samsung LED TV Model UA46D5500RR stuck on HDMI4
  • angelos
    • Dec 2012
    • 573
    • South Africa
    Hi Guys. Just a quick question. I have this SMART TV set that when switched on comes up with the smart logo and then reverts to HDMI4 input and stays there. I cannot make any changes via the front panel keypad or the remote. Its stuck on that input. It leads me to believe that the firmware or main board is faulty.
    My question is...... Is there a procedure where you take the firmware and reload it? I cannot do anything here because no buttons work. And the USB firmware update option is menu driven. Putting the firmware into USB1 and powering up the TV does nothing but start up the TV with the Samsung Smart logo.
    I cannot go into service mode with info, menu, mute and power since it automatically starts up.
    A quick observation yielded nothing out of the ordinary on the boards, I either want to do a firmware update or replace the main board.
    Any help here would be greatly appreciated.
  • Diah
    • Feb 2013
    • 6563
    Re: Samsung LED TV Model UA46D5500RR stuck on HDMI4
    little strange. but with several test could narrow the reason.
    1- each HDMI input socket are content signal sync pins if they are shorted at the socket the set will switch to it.
    2- you have another HDMI input socket with label "ARC" feed the set signal from ARC device and then switch on the tv.
    3- load photo on yours main boards and locate the SPI eeprom Label to know the pins out data sheet. some can be reset and other need to take out for dump then format--check blank and reprogram it with the dump again.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4539
      • Italy - Milan
      This model has an emmc/onenand and a Nand flash, the nand flash it is sold on ebay programmed but usually the fault with this tv is bootloop, i don't think this problem is software, switch on the tv then unplug power cord, open the tv and detach the local keyboard, switch on the tv and see what happens, if the keyboard contains the ir receiver you can' t control the tv but if the tv has antenna connected and alll hdmi disconnected and it positions on antenna source then replace keyboard..
      • angelos
        • Dec 2012
        • 573
        • South Africa
        1- I measured those 4 pairs of tracks from the HDMI socket to the CPU and compared them to another port, they were the same. All around 4 to 2 mega ohms. There is a 24CS02 chip also there. All resistances measure the same.
        2- I have HDMI1 / DVI. I put a signal and then switched on the TV. The set went straight to HDMI4. No difference.
        3. Not sure what you want me to do here. But i will add photo of main board. on next post.
        Thank you.
        • angelos
          • Dec 2012
          • 573
          • South Africa
          Here is a picture of the main board and a close up of HDMI4. Perhaps you can explain to me about the SPI chip here.
          • angelos
            • Dec 2012
            • 573
            • South Africa
            Originally posted by Davi.p
            This model has an emmc/onenand and a Nand flash, the nand flash it is sold on ebay programmed but usually the fault with this TV is bootloop, i don't think this problem is software, switch on the TV then unplug power cord, open the tv and detach the local keyboard, switch on the TV and see what happens, if the keyboard contains the IR receiver you can' t control the tv but if the tv has antenna connected and all HDMI disconnected and it positions on antenna source then replace keyboard..
            Ok, i unplugged tv, removed keypad which also has the remote sensor on it. I connected the coax plug. I doubt this tv is programmed to any RF channel previously so just RF noise could appear. There was no difference. TV went straight to HDMI4. All HDMI's were disconnected.
            • angelos
              • Dec 2012
              • 573
              • South Africa
              And i forgot to say that even though the source input is stuck on HDMI4 there is no image on the screen if i give it a DVD input.
              • Diah
                • Feb 2013
                • 6563
                i would remove 24CS02 chip of HDMI4 to terminated this input from the main cpu .. see what will happen.
                also look after samygo web.. how you can log in the set and delete profile setting files
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4539
                  • Italy - Milan
                  I suspect CPU soldering problem..
                  • angelos
                    • Dec 2012
                    • 573
                    • South Africa
                    But my remote does nothing, has no effect on the tv. Neither does the keypad. The red LED flashes when you press a button but nothing happens on screen.
                    So how can i delete user profiles???
                    • Diah
                      • Feb 2013
                      • 6563
                      if one key at keypad defect ( always close ) will have this issue too. disassemble keypad out from the set and exam all keys.
                      i wrote search after samyGo to know how to access the tv FW as its Linux system.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4539
                        • Italy - Milan
                        Already suggested keypad test, This model is near impossible to access linux shell without character security filter, i already have spent nights exploring the serial Menu , also tried bruteforce technique to find secret keys, found one but at least unuseful menu. SamyGo has no solution
                        • Diah
                          • Feb 2013
                          • 6563
                          what a rubbish, Samsung series until K / Hisense / MTK based TV can access and permit ROOT.
                          OP wish you luck with the professors over here.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4539
                            • Italy - Milan
                            How it is possible to avoid character filtering? SamyGo doesn't reveal..
                            Lets do judge by the op who are able to partecipate... please
                              09-07-2024, 05:50 AM
                            • Robby-Gr
                              TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                              by Robby-Gr
                              I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                              However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                              The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                              Additional issues:...
                              09-27-2025, 12:02 AM
                            • Daniel Larsson
                              Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
                              by Daniel Larsson
                              My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
                              I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
                              During these seconds the function button is not working...
                              08-13-2025, 10:29 AM
                            • GeckoGreen
                              Samsung service bulletin: need firmware file for PN63C550 TV
                              by GeckoGreen
                              I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
                              You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
                              The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
                              Will you please help me get the [2D63]LOGIC.bin file for my TV?
                              05-17-2025, 02:47 PM
                            • sikocan
                              NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
                              by sikocan
                              I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
                              However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
                              01-11-2024, 01:47 AM
