Test patterns on usb?
  • Hornnumb2
    • Feb 2011
    • 210
    Most of the time when I mess with TVs, I don't have any connection in my shop. Could I make some sort of usb stick to just cycle through video or test patterns?
  • nono34
    Hisense stuck in Colors cycle like test pattern.
    by nono34
    I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
    I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
    10-24-2024, 04:31 PM
  • patricksurry
    Sony Bravia XBR 55X900E cycling through test patterns: which board(s) to replace?
    by patricksurry
    We had a power outage but TV seemed to be working fine afterward. This morning it showed a "grainy" picture, and then next time we turned it on it's stuck in a test-pattern loop. None of the resets I've tried have any effect, including unplug/wait/plug in - it immediately goes into this cycling test pattern.
    Does this suggest the main board needs replaced? The TV is about 5 years old, picture still looks great (tho limiting to crisp red/green/blue/white lacks some variety ...
    04-08-2023, 06:45 AM
  • chth96
    How Can I test PWM DM0365R?
    by chth96
    Hello
    I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
    So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
    I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
    I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
    06-18-2025, 04:14 PM
  • khelane
    test active pfc power with lamp test
    by khelane
    Hello
    I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
    Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
    Is there a way...
    06-03-2025, 01:00 AM
  • chronic519
    Mats / mods: detected and repaired GPU fault. Cant seem to test after!
    by chronic519
    Hello.
    GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
    Found issue with a RAM block
    Replaced, green lines gone.
    Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
    Used a good card to test and same results low errors 32+.
    I am just search for some form of command to do a full test on the GPU.
    I just ran the mats command with my good GPU and passed after roughly 40 min.
    The repaired one, ran...
    05-20-2025, 07:56 PM
