Power board TP.S506.PC821 RB114 and RB115 burn
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Power board TP.S506.PC821 RB114 and RB115 burn
    Post a photo of the problem. May be easier than trying to explain it.
    • disorder
      • Sep 2015
      • 156
      • france
      Hello guys
      Holly fail! Damn shitty panel flex.
      The image issue was due to a bad connection
      TV works with small board and swap spi chip
      • DarkoOhrid
        • Apr 2012
        • 4
        • Macedonia
        I have a problem with TP.S506.PC821. Resistors, capacitors, transistors and integrated circuit are burn. Is there a schematic with values or a list of values for this board? Thank you
        • ttmi100x
          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
          by ttmi100x
          Greetings everyone,
          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
          Upon closer inspection...
          07-31-2024, 06:36 PM
        • Destroyer-Br
          [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
          by Destroyer-Br
          I'm working on an Acer Nitro 5 unit with the following specs:
          • Motherboard: LA-J871P Rev: 1B
          • Model: Acer AN515-55-59MT
          • S/N: NHQ7JAL00403906A973400
          • SNID: 03902728734
          Initial Issue
          The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
          After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
          04-17-2025, 08:18 PM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
          by sam_sam_sam
          After all of...
          07-13-2024, 08:14 PM
