Sharp LC-50LB371C LED TV VERTICAL LINES
  • TV HELP
    • Nov 2020
    • 13
    I’m new here and would love to get some help....I have a 5 year old Sharp LED tv with vertical lines.
    So far I have removed and cleaned most of the ribbon cables with no change.....any help with the next testing steps such as voltage checks or? would be highly appreciated.
  • TV HELP
    • Nov 2020
    • 13
    Re: Sharp LC-50LB371C LED TV VERTICAL LINES
    Could it be the t-con
      • 12210
      • U.S.
      I think it's a bad tab bond, try tapping on the bezel, NOT the screen where the line is, see if the line goes away or changes any.
      • neilc6
        • Nov 2015
        • 1550
        Only repeating lines/patterns may be tcon issues. Single random vertical lines or bands are bad panels.
        • TV HELP
          • Nov 2020
          • 13
          When I disconnect the 2 ribbon cables that leave the T-Con board and go to the panel the lines go away......not sure if this means anything?
          • TV HELP
            • Nov 2020
            • 13
            How do I test the T-Con board to confirm it works or not?
              • 12210
              • U.S.
              Try wiggle or shake the video input cables, see if that helps.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4333
                • Italy - Milan
                if you detach tcon outputs its normal that lines go.away since there is no more signal, locate the tabs where appears bad columns, then put a shim under them, then warm the back of the chip so on the amber side with a sokdering iron
                • TV HELP
                  • Nov 2020
                  • 13
                  Can you please send a picture of where I do this
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4333
                    • Italy - Milan
                    defenately not, i'm at hospital now..
                    • TV HELP
                      • Nov 2020
                      • 13
                      I hope you are ok!
                      • TV HELP
                        • Nov 2020
                        • 13
                        Are you in Milan Italy? I have been there!
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4333
                          • Italy - Milan
                          yes.. so basically,, if you detach tcon from the large screen boards , then you flip them you see the green part of the tab where there is a chip, ok you must put a shim under it provisional, then you put eveeverything normal and you warm under the chip especially in the zone that makes appear again the missing lines, so this test at tv switched on, i have near reapaired one this way.
                          • TV HELP
                            • Nov 2020
                            • 13
                            Any other ideas?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4333
                              • Italy - Milan
                              Buf why other ideas? I have given you an idea, you have done what?...
                              • TV HELP
                                • Nov 2020
                                • 13
                                I want to try your option I'm just not sure exactly what you want me to do
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4333
                                  • Italy - Milan
                                  sorry i can't explain it better
                                  • TV HELP
                                    • Nov 2020
                                    • 13
                                    Thank you very much for your help!
                                    • TV HELP
                                      • Nov 2020
                                      • 13
                                      • TV HELP
                                        • Nov 2020
                                        • 13
                                        I took part of the bottom bezel off and discovered a sticky substance on one of the I believe their called tab bonds maybe someone spilled something .....could this be an issue?
                                        I will be cleaning the area up and testing.
                                        • gpo23
                                          Sony KDL-40V3000 - Vertical lines
                                          by gpo23
                                          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                          With the new t-con the color are good but there are vertical lines on all the screen :
                                          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                          Is there a way to fix the vertical lines on the new t-con ?
                                          Thank you for your help
                                          gpo23...
                                          10-04-2023, 09:11 AM
                                        • viking509
                                          vizio e65 e3 LED tv color vertical lines center tv only
                                          by viking509
                                          I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                                          03-21-2023, 12:48 AM
                                        • srs
                                          Insignia NS-50DR620NA18 w/ large vertical lines & no picture
                                          by srs
                                          I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
                                          A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
                                          I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
                                          04-22-2023, 02:40 PM
                                        • polaro
                                          Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                                          by polaro
                                          Greetings,
                                          I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                                          08-27-2022, 08:46 AM
                                        • mtrionfo
                                          Sharp LC-70LE650U with colored vertical lines
                                          by mtrionfo
                                          Hi all - First post to the forum. I recently joined looking for possible repair of my Sharp Aquos 70 inch TV. Model number is LC-70LE650U. I have found lots of great troubleshooting guidance so I want to give a big THANK YOU to the regular posters here who share their time and knowledge helping everyone.
                                          After four years, my TV would not turn on and had flashing 2-5 error codes. Following the excellent advice of Freak and Bud that I found in older threads, I successfully removed the tabs and boards on the left side of my TV. The codes are gone, TV powers on and the image is bright...
                                          09-09-2018, 11:43 AM
