Sharp LC-50LB371C LED TV VERTICAL LINES
  • TV HELP
    • Nov 2020
    • 13
    I’m new here and would love to get some help....I have a 5 year old Sharp LED tv with vertical lines.
    So far I have removed and cleaned most of the ribbon cables with no change.....any help with the next testing steps such as voltage checks or? would be highly appreciated.
  • TV HELP
    • Nov 2020
    • 13
    Re: Sharp LC-50LB371C LED TV VERTICAL LINES
    Could it be the t-con
      • 12331
      • U.S.
      I think it's a bad tab bond, try tapping on the bezel, NOT the screen where the line is, see if the line goes away or changes any.
      • neilc6
        • Nov 2015
        • 1550
        Only repeating lines/patterns may be tcon issues. Single random vertical lines or bands are bad panels.
        • TV HELP
          • Nov 2020
          • 13
          When I disconnect the 2 ribbon cables that leave the T-Con board and go to the panel the lines go away......not sure if this means anything?
          • TV HELP
            • Nov 2020
            • 13
            How do I test the T-Con board to confirm it works or not?
              • 12331
              • U.S.
              Try wiggle or shake the video input cables, see if that helps.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4541
                • Italy - Milan
                if you detach tcon outputs its normal that lines go.away since there is no more signal, locate the tabs where appears bad columns, then put a shim under them, then warm the back of the chip so on the amber side with a sokdering iron
                • TV HELP
                  • Nov 2020
                  • 13
                  Can you please send a picture of where I do this
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4541
                    • Italy - Milan
                    defenately not, i'm at hospital now..
                    • TV HELP
                      • Nov 2020
                      • 13
                      I hope you are ok!
                      • TV HELP
                        • Nov 2020
                        • 13
                        Are you in Milan Italy? I have been there!
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4541
                          • Italy - Milan
                          yes.. so basically,, if you detach tcon from the large screen boards , then you flip them you see the green part of the tab where there is a chip, ok you must put a shim under it provisional, then you put eveeverything normal and you warm under the chip especially in the zone that makes appear again the missing lines, so this test at tv switched on, i have near reapaired one this way.
                          • TV HELP
                            • Nov 2020
                            • 13
                            Any other ideas?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4541
                              • Italy - Milan
                              Buf why other ideas? I have given you an idea, you have done what?...
                              • TV HELP
                                • Nov 2020
                                • 13
                                I want to try your option I'm just not sure exactly what you want me to do
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4541
                                  • Italy - Milan
                                  sorry i can't explain it better
                                  • TV HELP
                                    • Nov 2020
                                    • 13
                                    Thank you very much for your help!
                                    • TV HELP
                                      • Nov 2020
                                      • 13
                                      • TV HELP
                                        • Nov 2020
                                        • 13
                                        I took part of the bottom bezel off and discovered a sticky substance on one of the I believe their called tab bonds maybe someone spilled something .....could this be an issue?
                                        I will be cleaning the area up and testing.
                                        • Stanley1843
                                          by Stanley1843
                                          06-29-2024, 11:54 AM
                                        • pni
                                          LG 49uf695v vertical coloured lines
                                          by pni
                                          Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                                          11-14-2025, 03:15 AM
                                        • Falki
                                          Colorful LCD Vertical Lines on Samsung ue55es8090
                                          by Falki
                                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                                          A similar issue has been posted as well but also with no actual response ...
                                          08-12-2025, 04:19 AM
                                        • visionbluedemon
                                          Help. Sony kd-65x85dj vertical lines
                                          by visionbluedemon
                                          First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                          Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                          tried blocking LC lines too, but same results
                                          is it lcd panel issue or tcon board issue?...
                                          07-25-2025, 04:56 AM
                                        • gpo23
                                          Sony KDL-40V3000 - Vertical lines
                                          by gpo23
                                          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                          With the new t-con the color are good but there are vertical lines on all the screen :
                                          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                          Is there a way to fix the vertical lines on the new t-con ?
                                          Thank you for your help
                                          gpo23...
                                          10-04-2023, 09:11 AM
