Samsung 48' Vertical Lines
  • tezeteta
    • Sep 2020
    • 9
    • Ireland
    Hi Folks,
    My Samsung TV has some vertical lines. If I don't have any input connected to the TV, I can see just 2 lines (read and yellow - the 2 lines shown on the left side of the scroud image)
    Another symptom is that the COF tab is super hot.
    Do you think this is a screen issue?
    Thanks in advance,
    Tezeteta
    • 12084
    • U.S.
    Re: Samsung 48' Vertical Lines
    If that cof is "super hot" and the rest are not, then yep that area is the problem.
    • tezeteta
      • Sep 2020
      • 9
      • Ireland
      How can I make sure that the issue is the COF and not the screen?
      Is there any way to check it?
        • 12084
        • U.S.
        Are the rest of the cof's black like that?
        • tezeteta
          • Sep 2020
          • 9
          • Ireland
          The picture might appear to show a black spot on it, but it's not actually black.
          I cannot find any differences between COFs with my eyes.
            • 12084
            • U.S.
            Not sure, here's a guy who cut a track, not sure if it will work for your issue, I wonder if the cut-tape method would work for this issue: https://www.youtube.com/watch?v=6WOuIMt2W3U
              • 12084
              • U.S.
              Example of tape-cutoff method: https://www.youtube.com/watch?v=pfrRhw7-ZII
              • tezeteta
                • Sep 2020
                • 9
                • Ireland
                Thanks for your feedback nomoresonys.
                I will have a look on those videos and let you know how it goes
                  • 12084
                  • U.S.
                  Cool beans, what's it like in Ireland these days? We have pure chaos in the streets, here in the states.
                  • tezeteta
                    • Sep 2020
                    • 9
                    • Ireland
                    Ireland is kind of stoped :/ The government just move all the country to the highest restricting level. So the majority of the stuff is closed (pubs, restaurants, etc). Everyone that land in the island needs to do a 14 days quarantine. The numbers are still increasing (~1200 daily). Let's see how it goes...
                      • 12084
                      • U.S.
                      Not good news, our covid is exploding in most every state and...well I'll just quote one description...major "civil unrest"
                      • tezeteta
                        • Sep 2020
                        • 9
                        • Ireland
                        Hi nomoresonys,
                        I have try to apply the tape-cutoff method and I could get rid of the red vertical line, but not from the yellow one. Does this make any sense?
                        I apply the method in a random way as I don't have the pinout description of my tv board. Do you know any place where I can search for it?
                        • Stanley1843
                          by Stanley1843
                          06-29-2024, 11:54 AM
                        • x_orange90_x
                          Samsung UN46C8000XFXZA vertical bars/horizontal lines
                          by x_orange90_x
                          I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                          The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                          09-04-2023, 12:09 PM
                        • polaro
                          Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                          by polaro
                          Greetings,
                          I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                          08-27-2022, 08:46 AM
                          09-07-2024, 05:50 AM
                        • Anonmis
                          Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
                          by Anonmis
                          Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
                          The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
                          12-01-2023, 04:31 PM
