Westinghouse Service Menu ?
  • mmartell
    • Oct 2013
    • 3189
    Model WD55UDR101. I believe this was sold at Canadian Tire here in Canada.
    Want to limit the current to the leds - the standard Picture menu is useless for that. Trying to find it in the service menu before doing a hardware mod.
    Anyone know how to enter the Service Menu on this set or even other Westinghouse tv's ?
  • mmartell
    • Oct 2013
    • 3189
    Re: Westinghouse Service Menu ?
    Tv label and main/power board sticker.
    • Diah
      • Feb 2013
      • 6357
      search after Chinese main boards all in one service menu. like JVC too... you could also find at service menu the solution of yours other thread no speaker
      • neilc6
        • Nov 2015
        • 1550
        Try menu-0-0-0-0 source-2-5-8-0 or menu-1-1-4-7
        • mmartell
          • Oct 2013
          • 3189
          I believe I've tried the last two will try the first soon. Thanks.
          • mmartell
            • Oct 2013
            • 3189
            Was thinking that's a possibility will of course check it out if I can get into the service menu.
            • mmartell
              • Oct 2013
              • 3189
              Winner winner chicken dinner!
              Menu-0-0-0-0. Thanks neilc6.
              I haven't went through all the settings yet but what's better (or what's the difference?) between eeprom_init and factory_reset ?
                LCD LED TV Service Menu Codes
                TCL LED TV Service Menu Code
                LG LED TV Service Menu Code
                10-31-2024, 03:58 AM
              • tusiime
                How to access Vizio m652i-b2 service menu
                by tusiime
                The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
                So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
                Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
                09-15-2023, 09:57 AM
              • intercepter
                JVC LT-32CA120 service menu
                by intercepter
                I have JVC LT-32CA120
                Board:Vestel 17MB171
                I need rotate screen.It is possible in service menu and how to enter service menu?
                Thanks.
                12-10-2024, 10:29 AM
              • sohail5307
                I need how to open this Dell service menu option in dell latitude e6420
                by sohail5307
                I need to open service menu of Dell laptops like image in attachment
                Ignore my English
                I want beacause i flashed mec5055 using rt809h now it's does not have service tag, but when I install service using F2 in bios setup after save service tag and press disable manufacturing mode using alt+f then battery chagring is permanently disabled. I want to resolve this problem...
                01-13-2023, 05:56 AM
              • Storyteller12
                QN55Q60R Service Menu Panel Help
                by Storyteller12
                I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                01-13-2024, 01:57 PM
