Westinghouse Service Menu ?
  • mmartell
    • Oct 2013
    • 3189
    Model WD55UDR101. I believe this was sold at Canadian Tire here in Canada.
    Want to limit the current to the leds - the standard Picture menu is useless for that. Trying to find it in the service menu before doing a hardware mod.
    Anyone know how to enter the Service Menu on this set or even other Westinghouse tv's ?
  • mmartell
    • Oct 2013
    • 3189
    Re: Westinghouse Service Menu ?
    Tv label and main/power board sticker.
    • Diah
      • Feb 2013
      • 6496
      search after Chinese main boards all in one service menu. like JVC too... you could also find at service menu the solution of yours other thread no speaker
      • neilc6
        • Nov 2015
        • 1550
        Try menu-0-0-0-0 source-2-5-8-0 or menu-1-1-4-7
        • mmartell
          • Oct 2013
          • 3189
          I believe I've tried the last two will try the first soon. Thanks.
          • mmartell
            • Oct 2013
            • 3189
            Was thinking that's a possibility will of course check it out if I can get into the service menu.
            • mmartell
              • Oct 2013
              • 3189
              Winner winner chicken dinner!
              Menu-0-0-0-0. Thanks neilc6.
              I haven't went through all the settings yet but what's better (or what's the difference?) between eeprom_init and factory_reset ?
                LCD LED TV Service Menu Codes
                TCL LED TV Service Menu Code
                LG LED TV Service Menu Code
                10-31-2024, 03:58 AM
              • Robby-Gr
                TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                by Robby-Gr
                I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                Additional issues:...
                09-27-2025, 12:02 AM
              • tusiime
                How to access Vizio m652i-b2 service menu
                by tusiime
                The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
                So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
                Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
                09-15-2023, 09:57 AM
              • intercepter
                JVC LT-32CA120 service menu
                by intercepter
                I have JVC LT-32CA120
                Board:Vestel 17MB171
                I need rotate screen.It is possible in service menu and how to enter service menu?
                Thanks.
                12-10-2024, 10:29 AM
              • alltvrepairs
                Jvc Lt-65VU3000 reduce backlight from service menu
                by alltvrepairs
                I have just replaced led set of this vestel tv due to age.
                I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
                Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
                Thanks again....
                09-20-2025, 05:03 AM
